Go to Post That's just the thing about plastic or brass gears; they tend to morph into plastic or brass washers real fast. - Nick Seidl [more]
Unread 11-01-2011, 18:52
Spazbrodius's Avatar
Spazbrodius Spazbrodius is offline
AKA: Sean Nelson
FRC #2522 (Royal Robotics)
Spazbrodius is an unknown quantity at this point
Stabilizer legs
Is it against the rules of the game to make stabilizer legs that come down like a siege tank in Starcraft? they wouldnt touch the bumpers and only come down when placing tubes.
Pump mid!
Unread 11-01-2011, 19:02
Re: Stabilizer legs
Can you make them fit within the 60" diameter circle?
Can you make sure that they don't mess up the carpet?
If so, go ahead. Just bear in mind that while you're putting the legs out and in, every other tube scorer out there will be gaining a few seconds unless you're pretty quick at pulling them up/putting them down.
Unread 11-01-2011, 19:04
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Stabilizer legs
It's allowed to extend beyond the bumper perimeter after the start of the match, while your robot can fit inside an infinitely high 60" diameter cylinder.
<R07>.A:
BUMPERS must provide complete protection of the entire FRAME PERIMETER of the
ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT). As part of the 100%
coverage, BUMPERS must protect all exterior corners of the FRAME PERIMETER. For
adequate protection, a full segment of BUMPER must be placed on each side of the corner
(see Figure 3-2).
now we must ask, what is the frame perimeter?
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the HOSTBOT
(without the BUMPERS attached) that are within the BUMPER ZONE.
so what is a HOSTBOT?
HOSTBOT – the electromechanical assembly used to carry the MINIBOT. (ROBOT – MINIBOT =
HOSTBOT). If a TEAM plays a MATCH without a MINIBOT, then the HOSTBOT is the ROBOT.
so what is a ROBOT?
ROBOT – the composite electromechanical assembly designed and built by a FRC team to perfo
specific tasks when competing in the 2011 competition LogoMotion. The ROBOT must includ
the basic systems required to be an active participant in the game – power, communications,
control, mobility, and actuation. The ROBOT implementation must obviously follow a design
approach intended to play the 2011 FRC game (e.g. a box of unassembled parts placed on th
FIELD, or a ROBOT designed to play a different game, would not satisfy this definition). The
ROBOT includes both the HOSTBOT and the MINIBOT (ROBOT = HOSTBOT + MINIBOT).
Based on this alone, it would seem that anything going beyond the frame perimeter at any time and into the bumper zone would be illegal.
That would that tube pick up from the floor would be illegal as well.
I'm sure I'm mistaken about this, but I can't find the rule that would go around the above restriction...
Help!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 11-01-2011, 19:08
AKA: Sean Nelson
Re: Stabilizer legs
Thanks, wanted to know just in case
Pump mid!
Unread 11-01-2011, 19:14
Re: Stabilizer legs
Leav, if it's illegal to have anything going over the bumpers, then ain't nobody gonna be able to grab tubes from the floor. Just sayin'.
It's the 60" diameter cylinder that is the restriction here.
The FRAME PERIMETER cannot be articulated--that's in the robot rules. The legs would not be part of the frame perimeter during size/weight/starting/transit, as they're stowed. They are also articulated. As such, they're legal.
Or someone could just ask Q&A (this isn't it).
Unread 11-01-2011, 19:23
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Re: Stabilizer legs
I completely agree, and that's why my conclusion was that i'm wrong and missing something.
Currently the definition of the FRAMER PERIMETER, BUMPER ZONE and <R07>.A (all quoted above) seem to indicate that anything in the BUMPER ZONE would be part of the FRAMER PERIMETER, which would in turn require compliance with the bumper rules.
That would make building a mechanism to pick up tubes from the floor practically impossible.
I'd love to hear the loophole, otherwise i'll probably take it to the Q&A.
I'm sure they will allow pick up from the floor somehow but I think the rules will need to be amended.
maybe the FRAMER PERIMETER is measured only at the start of a match? (i.e. the starting configuration)
-Paraphrasing JFK
Re: Stabilizer legs
Leav,
The FRAME PERIMETER defines the size of the robot, where the bumpers must be attached and which all parts of the robot must start the match within. In other words, the STARTING CONFIGURATION without the height dimension. The PLAYING CONFIGURATION size is defined in the rules (and hopefully Team Update #1) and would allow stabilizers under certain conditions. The least of these involves the type and material used in contact with the floor and the risk involved in deploying said devices. This would open the device to damage and give opponents a greater ability to push your robot. If those risks fit your strategy then it may be worth the effort.
For example...
<R11> During the MATCH, the ROBOT may not exceed the volume constraints of either STARTING or PLAYING CONFIGURATIONS (note: these limits are defined in reference to the ROBOT, not the FIELD).
<R14> When a ROBOT is in its STARTING CONFIGURATION, no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER.
Unread 11-01-2011, 19:38
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Re: Stabilizer legs
Leav,
Al,
As you pointed out: FRAME PERIMETER is defined in reference to the ROBOT and not the STARTING CONFIGURATION, and PLAYING CONFIGURATION does not add any relevant information here.
Not trying to lawyer the rules around, just wondering: do you agree that the wording needs to changed to allow certain designs such as stabilizers and tube pick up from the floor?
-Paraphrasing JFK
Unread 11-01-2011, 21:31
Re: Stabilizer legs
Leav,
In Team Update #1 the dimensions for PLAYING CONFIGURATION has been changed to 84". I do believe that the stabilizers will fit that rule if other rules are also followed. However, I do not forsee a need for stabilization in this game unless the robot center of gravity is sufficiently high and unstable when outside of the scoring area.
Unread 11-01-2011, 21:36
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
Re: Stabilizer legs
I don't know who you are but I love you for making a Starcraft reference. I really have nothing to actually add to this discussion because your question has already been answered by other people, I just wanna say that you are awesome. That is all.
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
Unread 11-01-2011, 21:48
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Stabilizer legs
This isn't a question about whether stabilizers (or any other thing) are allowed to go into the 84" area. It's a question of what exceptions are there to the bumper rules for parts of the robot beyond the (starting) frame perimeter to pass through the bumper zone.
I came across this same problem in a design I was working on which would probably need wheels on the floor outside of the bumper area for stability. As far as I can tell the rules contain no exceptions for anything to pass through the bumper zone without having bumpers appear out of thin air. Even though I'm sure the GDC intended for manipulators to be able to enter the bumper zone, it is very important to know the specific exceptions granted to the bumper rules. We wouldn't want to have a major component of our robot rejected by inspectors at a competition
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 11-01-2011, 22:06
Re: Stabilizer legs
Rad,
There are specific bumper rules that I was referring to. As an answer to your proposal, from R07...
B. The BUMPERS must be located entirely within the BUMPER ZONE when the ROBOT is standing normally on a flat floor, and must remain there (i.e. the BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE). (emphasis mine)
If I understand your statement, you wish to have robot parts extend through the bumper zone, beyond the FRAME PERIMETER but not beyond the maximum PLAYING CONFIGURATION. The above paragraph would prevent that. A robot part that extends but is outside the BUMPER ZONE, does not appear to violate the above paragraph or any other rule at this point.
I recommend that you ask the question of the Q&A when it opens. The GDC is the only one that can provide you with a definitive answer.
Unread 11-01-2011, 22:19
AKA: Ian Thompson
Re: Stabilizer legs
Al,
I think you got my idea right. There would be arms that swing out to fill the 84" diameter and then have wheels on the end that reach through the bumper zone to the ground for stability.
Your interpretation demonstrates the problem though. If my device is forbidden, then any arm that has a claw which goes through the bumper zone to pick up a tube is also forbidden, which I really hope the GDC is not doing. I Do intend to take this to Q&A tomorrow though.
(PS It's funny the kind of ideas that pop into your head while trying to explain to your mentors why it would be illegal to have bumpers that reshape themselves during a match)
Unread 11-01-2011, 22:20
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Stabilizer legs
<R06> limits what kinds of materials can touch the floor.
Be sure to avoid <R05>
Overall I think it's possible to deploy outriggers for stability, but I think that designing for a lower center of gravity is a better idea.
Unread 11-01-2011, 22:52
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Stabilizer legs
The Blue Box in <G48> indicates that you can put things outside your BUMPERS during game play:
ROBOTS place mechanisms outside of the BUMPER PERIMETER at their own risk; no penalties will be assigned for incidental contact with such extended mechanisms.
However, this is the first year in which we had 100% BUMPER coverage and are able to expand outside the FRAME PERIMETER. To avoid inconsistencies, the definition of FRAME PERIMETER should be changed to indicate that it is measured in the STARTING CONFIGURATION only.
(since 2004)
