Go to Post Is it bad when are you just sitting at home wishing KICKOFF was here. - JulieB [more]
Unread 11-01-2011, 21:54
Re: 60 inch clarifiction
Even though the diameter has changed to 84" the method of inspection will remain the same. If your robot were designed that it could extend beyond the limit, you would be required to prove to an inspector that software is limiting the travel or extended size. The inspector would then notify the Head Ref who will watch your robot in action to be sure that the software or hardware limit is functioning as intended. The Head Ref can call for a re-inspect at any time to determine compliance or to recalibrate his(hers) vision.
