Go to Post I am not a moderator, but I am John V-Neun. - Billfred [more]
Unread 11-01-2011, 18:17
MylesMyles's Avatar
MylesMyles MylesMyles is offline
FRC #1631
MylesMyles is an unknown quantity at this point
Pulley help?
We are a team that has NEVER had and success with the pulleys on our lift designs. Does anybody have any recommendations for pulleys to use on a continuous lift system?
Unread 11-01-2011, 18:32
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: Pulley help?
Replace them with 25 chain and sprockets? I would use chain and sprockets over wire rope and pulleys any day.
Go REX!!!
Unread 11-01-2011, 19:00
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Re: Pulley help?
We've used synchronous pulleys and belts with success. What exactly were your issues?
Ed Sparks
MECH TECH FRC-3959
Unread 11-01-2011, 19:06
bearbot's Avatar
bearbot bearbot is online now
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
Re: Pulley help?
what easier for a third year team articualter arm forklift or pulley
Unread 11-01-2011, 19:21
MylesMyles's Avatar
FRC #1631
Re: Pulley help?
I'm not sure of the brand, but they were just simple little plastic pulleys about 1.75'' in diameter. We had the cables jump out of the pulleys a lot, although this may be because our lift did not have a retraction system (unless you count gravity...).
Do synchronous pulleys use belts?
Thanks for the responses.
Unread 11-01-2011, 19:27
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: Pulley help?
I would say yes.
make sure to get a belt with metal cables in the backing, this will provide the necessary strength to lift a forklift without snapping.
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 11-01-2011, 19:33
JosephBurns35's Avatar
JosephBurns35 JosephBurns35 is offline
AKA: Joseph Burns
FRC #2487 (Mechanical Animals)
JosephBurns35 is an unknown quantity at this point
Send a message via AIM to JosephBurns35
Re: Pulley help?
i to am planning on using a winch design on a forklift type arm how would you attach a chain. and still be able to role it up. if it matters i was planning on using a FP motor with a custom drum prob out of PVC seeing as how the arm isn't going to way much. if there is a better way please help.
Unread 11-01-2011, 19:49
MylesMyles's Avatar
FRC #1631
Re: Pulley help?
Is it a bad idea to use cable for the lift? My team would like to use a cable because it is simple, but will there be quite a big tradeoff in reliability of the lift by doing this?
I'm simply wondering because it seems that most of the people responding who have experience with this have used chains and/or belts.
Unread 11-01-2011, 19:59
AKA: Joseph Burns
Re: Pulley help?
i am also wondering the same thing i used cable for my arm last year and it was a pain if anyone has any other ideas i'm open for them thanks.
Unread 11-01-2011, 21:56
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Pulley help?
We used cable in 2007 and it was reliable and strong. Yes, it went 'haywire' once or twice, but easily corrected. In 2006 we used belting and that worked fine too. Cable (wire rope) can be 100% reliable if designed properly, and design is no more difficult than with chain or belts.
To the original poster: You need to tell us what went wrong with pulleys in the past. In general, pulleys and wire rope are good, but if you encounter a problem, you need to solve it. Once all problems are solved,. it works wthout problems.
Unread 11-01-2011, 23:21
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Re: Pulley help?
Another consideration could be cord used for climbing or something like 550 paracord. The 550 variety may be overkill, but it is more flexible than cable so it will "behave" better. By comparison a cable may be more inclined to stay bent/coiled/twisted/etc.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 12-01-2011, 00:58
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Pulley help?
There is a white paper in the white paper section on arms and lifts. In it you will find several ways to use cabling to achieve the results you want.
General guidelines are:
Power the lift up AND down, and make sure your cables cannot go slack.
If the cable must go slack, use guides to make sure the cable cannot come off the pulley.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
