Go to Post ...When you use ";"s instead of "."s; darn Java; - machman-2823 [more]
Unread 11-01-2011, 22:04
Deriboy Deriboy is offline
FRC #1891
Deriboy is an unknown quantity at this point
Minibot Tetrix Modification?
Does modifying (filing down a gear for example) Tetrix parts for use on a minibot comply with the rules? If not, can we make our own out of accepted materials like aluminium or polycarbonate?
Unread 11-01-2011, 22:11
Re: Minibot Tetrix Modification?
Deri,
As long as your modification does not violate
<R93> Motors may not be modified with exceptions of those in Rule <R47>.
This rule negates making changes to motors or integral transmissions other than for mounting. if the gear is internal to the FTC motor, then you may not modify. If it is an FTC mechanical part, there does not appear to be a rule that prevents it.
Unread 11-01-2011, 22:15
rocketeer1 rocketeer1 is offline
FRC #2993
rocketeer1 is an unknown quantity at this point
Polycarbonate and aluminum (in the form of sheets, 90 degree angles, u-channel, tubes and bars) is all allowed material, so you can machine, drill or do whatever you want to make parts out of it. See <R92>.
Unread 11-01-2011, 22:17
FRC #1891
Thanks.
Where is the Q&A?
Unread 11-01-2011, 22:35
DonRotolo's Avatar
Back to humble
FRC #0832
On the FIRST site, accessible for questions only to your team FIRST contact (usually the coach). But you can read all the answers you like. Once it opens...
Unread 13-01-2011, 14:57
Bmarquez Bmarquez is offline
FRC #3143 (Extreme Exotic Fire Breathing Rubber Duckies)
Bmarquez is an unknown quantity at this point
while this thread might not be the best place for this question,
ive combed through the minibot rules back and forth and up and down, and i cant find a direct answer of yes or no.
Does the minibot frame itself have to be made with tetrix parts?
because i'd much sooner make it out of an ultralight aluminum and drill/mount the parts myself then deal with the shoddy tetrix parts any longer then i already have today in class.
Unread 13-01-2011, 15:08
What is allowed for use by <R92>?
If it's on the allowed list, then it is allowed. If it is not on the allowed list, then it is not allowed.
Unread 13-01-2011, 15:10
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Per the rules, you could make the MINIBOT out of nothing but cable ties and wire nuts.
Unread 13-01-2011, 15:17
looks like me and my power drill are going to get very friendly tomorrow.... making a working frame out of sheet metal should be pretty quick to bolt together, and grind/polish/finish. According to the materials in part R92, sheet metal is allowed so i guess it was a silly question x.x.
i figure the extra zerospace allowed in a fully sheet metaled part will also keep the weight down and give me freedom in mounting/angling the pieces where i want them.
Thank you for clearing that up!
Unread 13-01-2011, 15:48
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
can i melt down the tetrix aluminum in a forge and pour sand castings to use on my pole-bot?
Unread 13-01-2011, 16:13
Matt C's Avatar
FRC #1468 (J-Birds)
Specifically sheet aluminum.
Unread 13-01-2011, 16:19
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
The following items are very vague with regard to modification (I expect more clarification as the season goes on but am curious to see your thoughts):
F. Polycarbonate
H. Aluminum sheet, 90° angle, u-channel, tube, bar
Q. PVC or CPVC pipe
In particular I am interested in manufacturing my own wheel with a "U" cross section (think of a pulley) where the radius of the "U" in the wheel is 1.74 inches/2 = 0.87". This would keep the minibot on the pole very nicely.
Can I machine or form this type of wheel out of polycarbonate stock?
Can I take a piece of U channel aluminum and carefully heat and bend it backwards using a steel guide to create this type of wheel?
Can I get four PVC 90 degree elbows, cut them in half along the radial center and glue them together to create this type of wheel?
Also - can the aluminum pieces be welded?
Unread 13-01-2011, 16:29
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Don't forget the battery.
Unread 13-01-2011, 16:33
And the motor(s), assuming of course that you want to go upwards.
Unread 13-01-2011, 17:19
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
And every thing else you need to actually play the end game ....
Originally Posted by Introduction_RevA
MINIBOT – an autonomous vehicle designed and built to perform specific tasks when competing in the 2011 competition LOGO MOTION. The MINIBOT must obviously follow a design approach intended to play the 2011 FRC END GAME and must be compliant with all MINIBOT rules defined in Section 4.4.14.
This message is hidden because Jack Jones is on your ignore list.
