Go to Post If it walks like a duck, and talks like a duck could be a very clever animatronics display created by Disney Imagineers.... Sometimes it is just a duck. - IKE [more]
  #76   Spotlight this post!
Unread 11-01-2011, 18:40
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: <R11> Dimension wrong?
Originally Posted by GaryVoshol View Post
That's the STARTING CONFIGURATION height, which has always been that way.
The PLAYING CONFIGURATION cylinder still has 213.4 cm. as of two minutes ago.
Still no update? I can't seem to open the robot rules from here.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
  #77   Spotlight this post!
Unread 11-01-2011, 19:45
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Team Update #1.
84" cylinder it is.
Nyuck, nyuck, nyuck.
Richard Wallace
since 2003
  #78   Spotlight this post!
Unread 11-01-2011, 19:54
Chris is me's Avatar
AKA: Pinecone
Originally Posted by Richard View Post
Team Update #1.
84" cylinder it is.
Wow, I've never been so happy to throw away 4 days of work.
  #79   Spotlight this post!
Unread 11-01-2011, 19:58
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
My faith in the GDC has been restored.
I have never been so excited for a team update.
-Dustin Benedict
  #80   Spotlight this post!
Unread 11-01-2011, 21:59
DonRotolo's Avatar
Back to humble
FRC #0832
Yay. 60" was a good challenge, but somewhat limiting.
  #81   Spotlight this post!
Unread 11-01-2011, 22:31
pfreivald's Avatar
AKA: Patrick Freivald
Me = sad. I liked the 60" restriction...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #82   Spotlight this post!
Unread 12-01-2011, 23:16
keericks's Avatar
keericks keericks is offline
AKA: Kent
FRC #1671 (Buchanan Bird Brains)
keericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of lightkeericks is a glorious beacon of light
So is the restriction for "possible" configurations or "programmed" configurations? For instance, if you have an arm that potentially could extend out past 84" barrier if rotated parallel with the ground, but programatically you don't allow that extension unti the arm is angled upward, not breaking the 84" restriction. Legal?
Or will the inspector have us extend the arm to its full length and then articulate it up and down to verify it never at any point breaches the barrier.
  #83   Spotlight this post!
Unread 13-01-2011, 07:16
If your programming prevents extension beyond the 84", you will have to prove that to an inspector. The inspector in turn will inform the Head Ref so that they can be aware that your program in intended to prevent breaking the 84" barrier. If they suspect a programming failure (and they do occur), they will then call for a re-inspect. In a case like this I usually recommend that a team design a secondary preventative in case a programmer inadvertently rems out the limit code.
  #84   Spotlight this post!
Unread 13-01-2011, 07:32
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
Uh-oh Al, I think you might have just dated yourself I don't think REM has been in any syntax since about 1985. Of, course TRON went extinct even before that. Note to self: write a movie script about a character named "TROFF".
  #85   Spotlight this post!
Unread 13-01-2011, 07:34
Alex,
Isn't REM valid in C++? I am just a hardware guy.
  #86   Spotlight this post!
Unread 13-01-2011, 07:52
ayeckley's Avatar
AKA: Alex Yeckley
Alex,
Could be. I'm not sure this newfangled C++ thing is going to catch on so I haven't adopted it yet. Also, all of my equities positions are in buggy whip futures.
  #87   Spotlight this post!
Unread 13-01-2011, 08:47
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Just be careful about using a CLU character. Maybe ALU? Maybe you could have a snake called Half Adder?
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #88   Spotlight this post!
Unread 13-01-2011, 12:49
Racer26 Racer26 is offline
REM is still valid VB syntax, I have never known REM to be a part of C/C++ (comments are //comment and /* comment */)
