Go to Post We may not build the best robots but we're building better students in the long run and means much much more. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Unread 01-11-2011, 11:41 PM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Mechanum wheel programming in C++
Originally Posted by johncap100 View Post
so Joe would you have an example of code we might use just to see how we might drive our bot? I have some kids who can program but they are just starting out and it would help alot if we had some code we knew worked and then could build on it
I've attached an example. It's based on the IterativeRobot base class but could be moved to SimpleRobot (by just putting a loop around the Drive method).
Did you use two joysticks?
Nope. Just one Extreme 3D Pro.
-Joe
