Go to Post For those of you who don't want to read a block of text: Respect the Tools. - Andrew Schreiber [more]
Unread 11-01-2011, 23:24
RJHermens RJHermens is offline
FRC #3187
RJHermens is an unknown quantity at this point
2010 KOP CIM motors vs. 2011 KOP CIM motors
Our team was thinking of using two CIM motors per CIMple gear box (total of four) but only two of these motors came in the KOP. However, we do have several of the KOP motors left from last year. The old and new motors look virtually identical but have different serial numbers. Does anyone have a spec sheet or know the difference between the two? Or is there a difference? And would it cause a problem if we mixed and matched?
Thanks!
-Ryan
Unread 11-01-2011, 23:27
Re: 2010 KOP CIM motors vs. 2011 KOP CIM motors
I don't know if there is a functional difference--I don't think there is--but what will tell you if they're legal is if they have one of the following part numbers: FR801-001, M4-R0062-12, AM802-001A, or PMR25R-45F-1003 (found in <R45-C>).
Unread 11-01-2011, 23:44
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
You might look at this thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=88592
-- Marshal Horn
Unread 12-01-2011, 20:23
FRC #3187
Thanks both of you for your quick reply, I do know that both motors are legal but what I was really wondering is if this year's and last year's are the same despite having different serial numbers and can they be the old and new work together in a gearbox?
Unread 12-01-2011, 20:27
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Yes, the CIM motors used last year and this year are the same motors and will work just fine.
Unread 12-01-2011, 20:33
FRC #3187
Sweet, thanks for the clarification.
