Go to Post The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning... - s_forbes [more]
Unread 11-01-2011, 23:59
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
Reaching for the Top Row?
We're a rookie team that has some experienced mentors and one experienced student. It's a talented group with a healthy amount of prior training. We're having serious discussions about whether to shoot for the top row or just settle for hanging tubes on the middle and/or lower row. To reach the top row requires a more complicated robot design (e.g., extending arm, multiple piece forklift, etc...) and these seem a bit much for an experienced team, let alone a rookie team.
thoughts? Scott
Unread 12-01-2011, 00:04
Chris is me's Avatar
AKA: Pinecone
Re: Reaching for the Top Row?
I'd say settle. There are only 6 spots on the top row - if you have alliance partners that can score on them, then they can probably manage 3 tubes each, or close enough to it. And if you can consistently dominate the middle and lower rows, you bet two good robots will pick you in the elims.
If you try the top and become a jack of all trades - but a master of none - you are a lot less appealing to an alliance captain. Do what you do well rather than do a lot of things badly.
Unread 12-01-2011, 00:11
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
You also might not make your alliance partners very happy if you blocked their view.
We've decided to avoid the middle row all together and either aim for the top or the bottom.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 12-01-2011, 00:13
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Another route to go is to be a "delivery" bot. Have one proficient scorer hang out in the scoring zone, while the other two robots bring it tubes from the other side of the field could be a winning strategy.
Go REX!!!
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
thoughts? Scott
One strategy that might prove good for you is the role of the fetcher. Design a small and really fast robot that can quickly and easily transport tubes from one end of the field to the other. I think the strongest alliances will have two hangers, each with their respective rack, and then one really fast fetcher.
A fetcher wouldn't have to have an arm at all but rather just be able to suck up tubes from the floor and drop them off for their hanger parters. The trick for such a strategy through is getting a chassis built as quickly as possible so your drivers can get used to the speed.
Unread 12-01-2011, 00:16
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Looks to us like you need about the same complexity to do the top row as you do the other rows...but the mecanism needs to be taller/longer.
We decided scoring on the top row is a high priority. There are a lot of ways to make a robot that can reach that high. Maybe look at some different arm ideas from other FIRST teams' past robots for inspiration.
pfreivald's Avatar
AKA: Patrick Freivald
A cascade forklift is not difficult to design, nor is it difficult to build -- especially for a team with any kind of depth whatsoever.
This will allow you to reach the top row no problem.
Please, do your team a favor and don't settle. 3x2x2 is just so much better than 2x2x2... And it doesn't block your drivers' vision.
Don't just aim to compete. Aim to win. (Winning doesn't matter. Trying to win does!)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 12-01-2011, 00:23
AKA: Pinecone
Scoring on the bottom and middle rows can be done with a single arm joint and no real expansion. Top row, nope.
Unread 12-01-2011, 00:25
mwtidd's Avatar
AKA: mike
For my team, 319, the fork lift has actually been our nemesis. We have never done well in years where we utilized an extension mechanism. We do arms, and we do arms well. Oh and by the way, we're actually team 6 (we were a test team one year) I realize that a lot of teams dont do arms very well either, hence why I suggested having neither. We are among the oldest teams in first, but we find forklifts difficult to build.
Oh and by the way, our coach specifically wants an alliance partner who is a fetcher. As a good fetcher you will actually look very attractive to many teams come time to pick alliances.
Why can't a single jointed arm cap the top?
Unread 12-01-2011, 00:37
Zoughtbaj's Avatar
Zoughtbaj Zoughtbaj is offline
Systems Integration Member
FRC #1983 (Skunkworks Robotics)
Zoughtbaj is on a distinguished road
The most important thing to keep in mind is the pros and cons of each level.
The higher row will yield the best points, but will prove to need a more complicated mechanism.
The middle row will yield decent points and will not need as complicated a mechanism, but will obscure your view of the field.
The bottom row has the least difficulty/physical consequences, but will score you the least points.
Just consider if the pros outweigh the cons, and judge on what you should do from there. For example, if a visual isn't needed because you have cameras mounted on your robot, then go for the middle if you like. Not to mention, there are various other strategies to attempt, as has been described already in this post.
"The Few. The Proud. The Skunks."
AKA: Pinecone
Sorry, cap the top and grab tubes from the floor.
Unread 12-01-2011, 03:12
kyoung kyoung is offline
FRC #0192
kyoung is an unknown quantity at this point
I would say go for the top row. This year is interesting in that the main game functions have been done and well documented. The gamepiece manipulators can be derived from 2007, and the lifting mechanisms from 2007/2008. There is a lot of value in looking at the successful robots from those years.
For lifting you generally have the choice between a multi-stage elevator or an arm. Both are rather simple mechanisms requiring 1 driven axel (usually 1-2 motors) and both can reach the top row without any excessive complications. There are pros and cons to both, but none are actually as significant as some would make them seem.
Remember, the inner tube has to be hanged, this does not mean that the lifting mechanism must reach the top rung. The bumpers must surround the entire frame perimeter. Your game piece manipulator must have some way of extending beyond the bumpers to pick up pieces (unlike 2007). If designed correctly, this mechanism can also get you the extra height boost to reach the top rung and if you're clever, you may not even have to power it.
Below are images of a quick sketch I drew earlier today illustrating an example of a basic robot design that can hang tubes on the top rungs of the scoring grid. (The gripper assembly could be powered by pneumatics or motors and the parallel bar linkage would be driven by motors with some sort of reduction.)
http://i.imgur.com/rDKI8.jpg (Dimensionless)
http://i.imgur.com/WjsFL.jpg (Dimensioned)
