Re: Is the FIRST Touch PsoC Board the only option??
If you want to use a different I/O board, you will have to write all of your own code to send the data to the robot and to access it on the robot, in addition to probably needing to write code for the board itself. It is not against the rules in general, though... you just have to follow any applicable rules.
-Joe |
R52 states that all signals must come from the OPERATOR CONSOLE, not the Driver Station software. If I recall UDP 1130 may be used for traffic from the Dashboard (Driver Station Ethernet network cable) to the Robot and UDP 1140 may used for traffic from the Robot to the Dashboard. -Joe |
On a slightly related note, it is possible to connect two PSoC boards to the DS laptop and prevent one from being seen by the DS app via custom firmware, then use a custom driver to supplement the I/O ports we usually get? |
I can't say I've ever tried that. I can't think of an easy way to do it. The DS may only read from the first one, but which one is the first one will probably not be something you have control over aside from unplugging the extra one every time you start the DS.
