Go to Post I was a rookie last year, I didn't expect much. Now I got a taste of what it is, I want more. - davidthefat [more]
  #31   Spotlight this post!
Unread 10-01-2011, 13:57
Re: 2011 Minibot electronics
It has also been pointed out (offline) that a tether would not fit in the 12" cube. Food for thought.
  #32   Spotlight this post!
Unread 11-01-2011, 22:21
Nishant Nishant is offline
FRC #0008 (Boeing and Palo Alto High School Robotics)
Team Role: Electrical
Nishant is an unknown quantity at this point
For those of you interested in using NXT equipment:
FIRST now allows:
BB. NXT compatible sensors and related connectors/cables.
(Team Update 1)
  #33   Spotlight this post!
Unread 12-01-2011, 09:40
bookman101 bookman101 is offline
FRC #0219
bookman101 is an unknown quantity at this point
Your minibot has to be an electromechanical devises as stated in the logomotion summary, and your could possibly use a tether as long as you can assure that it will never touch the pole. The tether would be considered part of the hostbot by my understanding and would violate the rule of the host bot touching above the deployment line.
  #34   Spotlight this post!
Unread 12-01-2011, 10:13
A tether between the HOSTBOT and the MINIBOT will mean that you won't be deploying the minibot, according to the clarified definition of DEPLOYMENT. The act of deployment ends the moment the HOSTBOT and MINIBOT are no longer in contact, and only then can the MINIBOT start upward.
  #35   Spotlight this post!
Unread 12-01-2011, 10:36
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Originally Posted by Bruceb View Post
I think the battery statement is vague. Do you read it as the mini bot MUST have a battery?
It seems we could build a recoil motor with the surgical tubing??
Hmm
Team update #1 yesterday saying it MUST be electrically powered climbing ability
  #36   Spotlight this post!
Unread 12-01-2011, 11:09
Kdabr Kdabr is offline
FRC #3626
Kdabr is an unknown quantity at this point
What about deploying a minibot that has a base module (containing a battery and controller) that would be tethered to the actual climbing bit? I think this would be legal because a minibot would still be deployed, but only half of the minibot would climb...right? The base module would rest on the pole's circular platform while the upper part climbed.
  #37   Spotlight this post!
Unread 12-01-2011, 11:10
GaryVoshol's Avatar
Cogito ergo arbitro
The pole is more than 12" high ... just sayin'
(all of it)
(since 2004)
  #38   Spotlight this post!
Unread 12-01-2011, 14:46
blueyes2821 blueyes2821 is offline
FRC #0888
blueyes2821 is an unknown quantity at this point
An earlier post on this page listed required materials. non metallic rope or cord is allowed, so that may be possible.
  #39   Spotlight this post!
Unread 13-01-2011, 23:31
keyslammer keyslammer is offline
FRC #1388
keyslammer is an unknown quantity at this point
They've clarified that no "stored energy" other than what would be in a battery can be used. So you MUST use the electrical energy to move your minibot. Basically, you have to have the battery.
  #40   Spotlight this post!
Unread 14-01-2011, 20:23
perry3018 perry3018 is offline
FRC #1543
perry3018 is an unknown quantity at this point
well if the mini bots can't have the Samantha then how would we enable the automatous on it?
  #41   Spotlight this post!
Unread 14-01-2011, 23:25
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
The minibot is always in autonomous mode waiting for a sensor to tell it to start climbing. Please refer to the other thread here.
http://chiefdelphi.com/forums/showthread.php?t=88644
  #42   Spotlight this post!
Unread 15-01-2011, 00:01
DonRotolo's Avatar
Back to humble
FRC #0832
Only if the minibot never exceeds 12" x 12" x 12". That doesn't allow for much in the way of rope dangling down.
We had thought of a small mechanical lever that, when the minibot hits the top, releases a cord we can pull after the match to retrieve the minibot, but this would have the minibot larger than 12", and so was ruled out. We decided to stick with the pole-mounted chainsaw.
  #43   Spotlight this post!
Unread 17-01-2011, 07:28
Deployment is initiated by the drivers. The only interaction with field control comes when all four posts have been triggered or the match clock runs out.
  #44   Spotlight this post!
Unread 17-01-2011, 09:49
SciDKelly134 SciDKelly134 is offline
AKA: Dave Kelly
FRC #0134 (Team Discovery)
SciDKelly134 is a name known to allSciDKelly134 is a name known to allSciDKelly134 is a name known to allSciDKelly134 is a name known to allSciDKelly134 is a name known to allSciDKelly134 is a name known to all
Send a message via AIM to SciDKelly134
2011 Minibot electronics - 4 pole switch
GDC
Re: Minibot Light switch
For the purposes of FRC 2011, a standard light switch is considered any standard switch which is normally installed in a wall box to control lights in a home.
We purchased a 4 pole (wall box) light switch from Home Depot and it works very nicely to reverse the DC polarity. On our prototype, we used a standard switch to turn the robot on and the 4 pole switch to bring the minibot back down the pole
