Go to Post Being professional means doing things right. Being gracious means doing the right thing. They complement each other perfectly. But I think we should remember to use GP as a guide for our own behavior, not as a yardstick to measure others' shortcomings. - Alan Anderson [more]
Unread 11-01-2011, 10:56
Chris is me's Avatar
AKA: Pinecone
Re: Feeder Bot
Originally Posted by Tetraman View Post
I would think it's not an issue of getting them to go where you want it, but about getting the most tubes over to your side of the field as fast as possible.
We also could never, ever, ever get a tube 45 feet.
That being said... if someone were to pull it off...
Unread 11-01-2011, 10:58
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: Feeder Bot
Maybe it wouldn't sit there, it might drive out to the edge of the blue feeder zone and shoot them off there...or it just hands pieces to allied robots.
As of right now, we can't just hand pieces to allied robots (the rule doesn't make an exception for allies as written). Dropping them in front of other robots is an option, as is what you also suggested - shooting them off.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 11-01-2011, 18:18
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
Re: Feeder Bot
As far as imparting spin goes couldn't you just have a simple design, like two parrallel sets of wheels to accelerate the tubes. If you ran one set of wheels faster than the other, it should give it some spin. I was thinking if you got it optimized enough you could even curve it around the pole by the safe zone and try to get it to land in the middle of the safe zone in front of your pegs.
Unread 11-01-2011, 19:14
Erik Huang's Avatar
Erik Huang Erik Huang is offline
Jack of all Trades, Master of None
FRC #0296 (Northern Knights)
Erik Huang is a jewel in the roughErik Huang is a jewel in the roughErik Huang is a jewel in the rough
Re: Feeder Bot
This was HUGE in our strategy meetings; we even found some really effective elim. strategies using this;
don't forget, to bring 6 tubes across the field in one game, you'd have to make the roundtrip in under 15s, without obstruction. most team will realize that, so they might be throwing into the field as well.
Here ye, here ye! Here cometh the robot!
Unread 11-01-2011, 21:42
Erik Huang's Avatar
Re: Feeder Bot
out of curiosity, i was wondering the dimensions of the pin/peg on the scoring rack/alliance wall: i know it's make of, essentially, a cylinder with a flange on the end: what is the radius/diameter/circumference of the flange?
Unread 11-01-2011, 23:36
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Chickenonastick is on a distinguished road
Re: Feeder Bot
Sounds like a lot of work for the tube dispenser
Unread 12-01-2011, 00:31
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: Feeder Bot
If I were to do this I would make the robot receive the tube out of the slot, rotate it 90 degrees, then catapult it over the field.
Go REX!!!
Unread 12-01-2011, 10:04
FRC #2635
Re: Feeder Bot
Do you think it would fly further in a vertical position?
Unread 26-01-2011, 16:07
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
Re: Feeder Bot
I will have for you tonight video of team 73's prototype that Accurately shoots all sized tubes 10+ feet in the air and over 30 feet.
It was working yesterday but my camera was not
I am really excited because the feeder concept is slowly becoming a reality!
Unread 26-01-2011, 16:19
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Feeder Bot
Hmm, I really want to see this. Sounds impressive. At this point in time, its a little late to change our pace, but this sounds very interesting...
Unread 26-01-2011, 16:26
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Feeder Bot
I would applaud if you guys can manage to get your human feeder to just keep chucking tubes at it and your robot spits them out while on the edge of the lane safe from pesky robots.
Unread 26-01-2011, 16:58
Re: Feeder Bot
I think optimally we would not even need to move. Which would allow a more rapid fire, shooting tubes at about as fast as the human player can load them, approximately 2 - 4 seconds. For this to be viable we will need to add another 15 feet on to our range, but keep in mind this is a prototype made out of 4 pieces of wood and is not the most sturdiest of mechanisms.
Unread 26-01-2011, 19:43
jyh947's Avatar
jyh947 jyh947 is offline
FRC #3322 (Eagle Imperium)
jyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to behold
Re: Feeder Bot
If a human player were to throw a game piece, would hitting a tower cause your team to receive a red card?
Unread 26-01-2011, 19:51
rawrbot's Avatar
rawrbot rawrbot is offline
AKA: Nelly
FRC #1778 (Chill out!)
Team Role: Mascot
rawrbot is an unknown quantity at this point
Re: Feeder Bot
I am looking forward to seeing this feeder in action. i've been prototyping a tube launcher but wasn't able to get past 20 feet. a launcher feeder would be a huge advantage to any alliance.
Unread 26-01-2011, 20:03
As Promised... Team 73 Teaser!
http://www.youtube.com/watch?v=jrgc6KNDgY8
Distance: Triangle 27 feet, circle 30 feet, Square 28 feet, also the side to side was Fairly accurate.
Height: we had to limit the height because we were in a room with a ceiling but it was still at least 12 feet
The design is using two single surgical tubes tied on either end.
Ideally I would like to get about 10 more feet out of a final design but I think that will come with a more rigid design
as always any thoughts or suggestions you have are welcomed
