Go to Post Something is subtly different about the competition environment that makes everything worse. - kaszeta [more]
Unread 09-01-2011, 16:50
isaacdl isaacdl is offline
I have a white hat..it's just dirty
AKA: Isaac Dontje Lindell
FRC #3018 (Nordic Storm)
isaacdl is an unknown quantity at this point
How to install Java on Classmate
Does anyone know where we should download the stuff we need for Java developement? I could download the JDK and Netbeans from the Netbeans site, but I haven't a clue where to get SunSpot.
I'm assuming the image to reimage the cRio is included somehow in that stuff? Right now when we try to reimage, the Imaging Tool says it can't find any images.
Also, like I said in another post, we have well under a gig of space left on the Classmate hard drive. The restore key seems to have created a 5.4 gig recovery partition. I'm concerned we won't have enough space to install the necessary stuff.
Unread 12-01-2011, 01:06
Kevin Wang's Avatar
Kevin Wang Kevin Wang is offline
Software Engineer, Webmaster
FRC #0694 (StuyPulse)
Kevin Wang is an unknown quantity at this point
Re: How to install Java on Classmate
First install that JDK + NetBeans bundle. Once NetBeans is installed, then in NetBeans go to Tools > Plugins. Go to the Settings tab, click on Add, and for the name make it something intuitive like "FRC Java". Use the following URL:
http://first.wpi.edu/FRC/java/netbea...te/updates.xml
Click OK, and then go to the Available Plugins tab. Check the five FRC plugins and press Install. Follow the prompts and after you restart NetBeans, voila.
Unread 12-01-2011, 12:24
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
If you give me your email, I'll give you a link to my drop box and my video walkthrough to getting set up with Java in 2011
