Go to Post Q&A is certainly a good route to take, but depending on how gray the topic in question is, CD is certainly a good place to ask the question. - slijin [more]
Unread 12-01-2011, 12:32
Andy Grady Andy Grady is offline
I'm done being quiet!
FRC #0131
Rookie Year: 1995
Andy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond reputeAndy Grady has a reputation beyond repute
Send a message via AIM to Andy Grady
Re: Team Update #1
I for one am thrilled at the lastest team update. During a match, while I am announcing I stand right next to the field...I didn't really like the idea of taking a 15 pound piece of metal to the squash because someones latch failed to activate and the spring misfired. Phew!
To anyone who thinks this will not be exciting, you are out of your mind! It is NOT like hanging first off. You did not get more points for hanging first as you do for finishing first with the minibot. That 10 point difference between 1st and second could be a huge make a break moment in an elimination match. To me, it doesn't get any better than that!
As for the design challenge...if you don't think there is a challenge in trying to get your minibot to go faster than everyone else, you are not thinking outside of the box enough in my opinion. Once again, instead of complaining, suck it up, think a little harder, and make the most of what you do have.
From what I can tell, there are ways around, or ways to alleviate all the complaints which people have posted here...all it takes is for a little hard work. Get on it!
My only actual question is this...who can register a minibot? An FRC team? An FTC team? A team of random mentors and students with no affiliation? A team of mentors with no affiliation? A volunteer? I don't see this clarified anywhere...it might be slightly important to know.
Good luck everyone!
Unread 12-01-2011, 12:48
Chris is me's Avatar
AKA: Pinecone
Re: Team Update #1
The difference is that with hanging, there are a multitude of different designs and options. Between looking cool, going up fast, elevating past the buzzer, and otherwise, there is a lot of variety that is exciting to watch.
This game, the laws of physics pretty much dictate a maximum speed and there's maybe one or two ways to reach that speed - so it becomes a "race" in who deployed right at the 10.0 mark, or who got a lucky battery charge, rather than an actual demonstration of which team had a better engineered mini bot.
Unread 12-01-2011, 12:50
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Team Update #1
There is quite a bit of engineering and design work involved in objectively reaching that 10.0 mark that should not be tossed aside.
Hi!
Unread 12-01-2011, 12:57
AKA: Pinecone
Re: Team Update #1
Don't forget: the difference between "wow, what a great deploy, first place" and "the refs have disabled your tower" is so infinitesimally small and so much more important than previous end games that I can see nothing good coming of it.
Either teams will release early and get away with it or teams will jump the gun and get their tower disabled based on a number the field cannot precisely display and that no one can see while simultaneously staring at the base of the tower.
Unread 12-01-2011, 13:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Team Update #1
I can't believe veterans here on CD are turning the Update into a VRC/FTC gripefest. This was a minibot challenge, not a PVC tube launching challenge. It's sickening that people are crying foul just because now they're forced to use a 'competing' or 'inferior' product. If you don't like the product because of principles, then don't do a minibot on principle. The rest of us who aren't strong-armed into one program or another will enjoy seeing the minibots make it to the top.
Karthik, Cory, if I didn't respect you two so much for your technical prowess and general logical GP practices I would be hard pressed to hold back the tirade I could type right now.
GitHub
Unread 12-01-2011, 13:10
Re: Team Update #1
Jesse, even those of us who do neither FTC nor VEX and who are sitting out the FRC competition are complaining. It's turning a mousetrap car (with the option for FTC) into an FTC robot. That could be good, or it could be bad, but either way it's changing the rules in a major way.
There were a number of ways to eliminate unsafe launching and declare a minimum weight equivalent to the FTC battery. Minibots must contact the tower during the entire deployment, minibots must have a minimum weight of X, the list goes on. Instead of one that allows for stored-energy designs, they went with the most restrictive rule they could. After teams had already started their FIRST Choice ordering.
Unread 12-01-2011, 13:22
FRC #0131
Rookie Year: 1995
Re: Team Update #1
Eric,
You aren't really taking mechanism failure into account. Just saying that a robot has to be constantly touching the bar during ascent, doesn't mean that it will happen in actuality. When you consider vibration, massive collisions, robot failures, having a 15 pound spring loaded vehicle on your robot is incredibly hard to make safe, let lone the damage it could pose to your own robot's internal systems.
Unread 12-01-2011, 13:46
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Team Update #1
Ummm, my posts in this thread have been about how 148 & 217 didn't have a hanger on their robots during the 2010 competition season. I also commented on how I enjoy Cory's blunt statements. ("I have no desire to watch a battle of who sucks less." I thought this was hilarious) Nowhere did I mention VEX, VRC, FTC, minibots, competing products or anything else. I've included links for your reference.
http://www.chiefdelphi.com/forums/sh...9&postcount=22
http://www.chiefdelphi.com/forums/sh...5&postcount=35
So if you respect me so much, please consider not putting words in my mouth. I have no problem standing behind the words that I've actually spoken, I have a hard time doing the same with ones that are being conjured out of the over active imaginations of others.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 12-01-2011, 13:49
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Team Update #1
Jesse it's not about FTC vrs VRC, I think FIRST's behavior and decisions fly's in the face of their stated mission of inspiration for purely selfish reasons. I (and judging form the many PM's I have received, many others) think they are acting in a very un-GP way.
Are you suggesting that I just not say anything and sit back and smile while the program that I love is corrupted?
Unread 12-01-2011, 13:50
AKA: Pinecone
Re: Team Update #1
Find a post in this thread where either Karthik or Cory posted anything about Vex, VRC, or even FTC. You can't. That's not what they were complaining about at all.
Unread 12-01-2011, 14:04
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Team Update #1
Okay everyone I think that this is going way too far! I've calmed down since last night a little and realized oh well, then we will make sure that we do whatever we can to save every ounce of weight and get up as fast as we can. Hey, someone has to be the first up that pole! So what if our design is no longer legal or our arm doesn't have to fit a 60" constraint. Let's move along with the season. Things like this happen all the time and how we deal with it determines character. This past weekend our store did inventory and I spent 2 hours counting thousands of packs of cigarettes. When we are about to finish up and every other employee is leaving my group is told that we were given the wrong format and that we need to start over and none of our numbers were valid. I was originally furious because all I had on my mind was the new challenge, but complaining didn't get it done or get me home faster. Hey, maybe Andy Grady is on to something. The minibots will be a very on the edge of your seat ending when it is all tied up and all four are neck and neck.
FIRST is making their decisions, we are not being forced to compete in FRC, get over the update, get over each other, and make your robot!
1058 PVC Pirates 2016 - xxxx
Unread 12-01-2011, 14:18
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Re: Team Update #1
Let me share a quick story.
While Alan Shepard was sitting at the top of his Mercury space craft waiting to be the first American into space, there had been several issues, the count-down had been stopped and restarted several times. At T- minus two minutes and forty seconds and counting, Shepard heard that dreaded word again, "Hold". Another problem had stopped the countdown, yet again. Getting frustrated, he yelled, "I've been in here more than three hours. I'm a h*** of a lot cooler than you guys. Why don't you just fix your little problem and light this candle?"
The countdown to the ship date is ticking. So let's all be cool, and
Light this candle!
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2016: Greater DC, Central MD, Chesapeake District Championships, Championships
Unread 12-01-2011, 14:21
CMills CMills is offline
FRC #1529 (CyberCards)
CMills is an unknown quantity at this point
Re: Team Update #1
Originally Posted by BrendanB View Post
Okay everyone I think that this is going way too far! I've calmed down since last night a little and realized oh well, then we will make sure that we do whatever we can to save every ounce of weight and get up as fast as we can. Hey, someone has to be the first up that pole! So what if our design is no longer legal or our arm doesn't have to fit a 60" constraint. Let's move along with the season......
I have to say, this is probably my favorite post. The truth, the real bottom line. Things CHANGE. We are an organization of engineers or at-least engineer-like minds.....since when do things not change. Somebody tell me one robot they built that not one thing changed. Whether it be a controled factor or not.
It's a trade off. Bigger play radius, more contraints on the mini bot. I see nothing wrong with that.
P.S. FTC, VRC....can you say NASCAR vs IRL?
Both are the same "sport" both have their parts and their rules. We compete in the FIRST Robotics Competition, therefore I don't see it unreasonable to use FTC parts, if this were something different then I would make that claim later.
Unread 12-01-2011, 14:46
CassCity2081 CassCity2081 is offline
AKA: Matt Cassidy
FRC #2081 (Icarus)
Team Role: Electrical
CassCity2081 has a spectacular aura aboutCassCity2081 has a spectacular aura about
Re: Team Update #1
The one thing that I don not understand is peoples comments about "clone bots". If anything this team update got away from having everybody being a one pound box on a surgical tube slingshot that if everything went just right it would hit the top tower and not damage the field and if anything went wrong it would result in injuries to robots, the field, or people. Try not to get mad that everyone thought they found a 469 like loophole to the game and the GDC didn't let it go. There is still plenty of time for new concepts, if you didn't like a challenge like this you would not be a part of FIRST.
Unread 12-01-2011, 14:47
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: Team Update #1
Just wondering but didnt they change vex/FVC to FTC? isnt Vex = First Tech Challenge? So people saying Karthik is pro-vex and anti-ftc is contradictory.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
