Go to Post Big Mike (i'm not big you are all just short ;) ) - Mike Schroeder [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 12-01-2011, 14:01
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Re: Updated CAN Jaguar Issue
Originally Posted by Alexander Meyer View Post
Now, all our code (which is also exactly the same) fails at jag initialization with an UncleanStatusException. In the past, this problem had to do with a low battery, but we hooked up a fully charged one and the problem still persists. We also tested the jags with BDC-COMM v92, and they work perfectly. Is there anything else that needs to be updated/changed to get these working?
Does your code retry when getting the exception, or just give up without retrying? Last year we noticed that we'd occasionally get the UncleanStatusException at initialization of the first Jag, and as best we could tell seemed to do with sensitivities with all the inter-task communications - i.e. the WPI library calls FRC_NetworkCommunication, which in turn calls the plugin main task, which calls send/receive tasks.... - I'd have to check with the team to see exactly where the diagnosis led.
In any case, we solved it by wrapping the constructors in a try block, and putting that in a loop so that we kept retrying the initialization until successful. The first Jag would occasionally have to be tried a couple of times before success.
- Ron
Team #2607 controls mentor
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
