Go to Post Geez, now I'm like some all-knowing all-seeing FIRST sage who lives in the moutains waiting for students to venture upwards to my home to ask me if there will ever be a water game....:rolleyes: - Koko Ed [more]
Unread 12-01-2011, 14:41
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
Compound Miters in Tube
Does anyone know how to make a compound miter in Inventor. It is probably easy and I am just missing the idea. I want to take 1" square tube and put a 8 degree angle on one side and a 10.4 degree angle on the other.
Please help!
Unread 12-01-2011, 14:45
tonystark_23's Avatar
tonystark_23 tonystark_23 is offline
FRC #2975
tonystark_23 is an unknown quantity at this point
Re: Compound Miters in Tube
I'm sorry I might be understanding wrong but are you attempting to make a shape similar to a lathe bit?
Unread 12-01-2011, 14:48
FRC #2791
I guess so...I want to be able to angle the tube both in and back at the same time.
Unread 12-01-2011, 15:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
A work plane or two is probably the easiest way to do this. They're imaginary planes you create in relation to other surfaces. Like, at X degrees to another plane or face, rotated about a line/axis. Then just make a sketch to cut away all the offending material.
EDIT: Just played with Inventor a bit to verify something. Face Draft is an even better and easier way to do a compound miter like this. It takes two steps, but it's still pretty simple. Play around with it a little.
Unread 14-01-2011, 21:42
FRC #2791
You solved it! Thanks. I knew there must be an easy way to do it. I appreciate your help.
Unread 20-01-2011, 15:33
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Kevin,
Thanks for your solution on the compound miter.
If I understand the problem correctly another solution is using Frame Generator. It contains tools that automatically trim the intersections of frame members.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
