Go to Post Using a mouse is so 20th century! - Tom Bottiglieri [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 11-01-2011, 20:26
Alexander Meyer Alexander Meyer is offline
FRC #2358 (Bearbotics)
Alexander Meyer is on a distinguished road
Updated CAN Jaguar Issue
Hey y'all! Question.. (correct me if this should go in the Java section)
During the offseason, our team got an old swerve chassis up and running with five black jags hooked up to the cRio via the serial interface. We programmed the whole setup using Java. After kickoff, we moved the controller board to a new prototype chassis--all CAN and encoder wiring stayed exactly the same. We then updated:
1) cRio -> image v25, with black jag serial plugin selected
2) Driver station
3) Black jags -> firmware version 92
4) Netbeans plugins
Now, all our code (which is also exactly the same) fails at jag initialization with an UncleanStatusException. In the past, this problem had to do with a low battery, but we hooked up a fully charged one and the problem still persists. We also tested the jags with BDC-COMM v92, and they work perfectly. Is there anything else that needs to be updated/changed to get these working?
Unread 11-01-2011, 21:36
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Updated CAN Jaguar Issue
Please excuse my unhelpful and indeed useless post in advance, and PLEASE do not follow this advice. Thank you.
Wash the jaguars so they are clean again.
Unread 11-01-2011, 21:44
We tried that, but it resulted in a WetStatusException; we let them dry, but apparently they got dirty again..
Unread 11-01-2011, 21:48
Time to go home, Don.
Unread 12-01-2011, 12:06
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Unclean can be caused by multiple issues. When we first dabbled in it we cam across three. Cant recall the numbers but one was that the jag plugin wasn't loaded. One was because one of the students loaded the serial plugin and the 2can plugin. The last error was because there was a short on the can bus (particularly the serial plug terminating resistor)
So to summerize ...
Check your can network
Check to make sure you have added the plugin to the cRio
Check that it is loading
Make sure you don't have both plugins loaded
Unread 12-01-2011, 14:01
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Does your code retry when getting the exception, or just give up without retrying? Last year we noticed that we'd occasionally get the UncleanStatusException at initialization of the first Jag, and as best we could tell seemed to do with sensitivities with all the inter-task communications - i.e. the WPI library calls FRC_NetworkCommunication, which in turn calls the plugin main task, which calls send/receive tasks.... - I'd have to check with the team to see exactly where the diagnosis led.
In any case, we solved it by wrapping the constructors in a try block, and putting that in a loop so that we kept retrying the initialization until successful. The first Jag would occasionally have to be tried a couple of times before success.
- Ron
Team #2607 controls mentor
FIRST Mid-Atlantic Volunteer
FRC Team #2607 Mentor
Unread 12-01-2011, 14:29
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
2) Driver station
4) Netbeans plugins
Please let me know what the actual status code is. I'm also in the process of cleaning up the exception handling in the Java implementation. I know it is not good at the moment.
-Joe
Unread 12-01-2011, 14:32
The status code is -52007.
Unread 12-01-2011, 14:39
That's a timeout. It may be that you are trying to talk to a device number that you haven't assigned on the bus or have a problem with the bus termination or there is a bug in the CANJaguar class. Have you tried it in LabVIEW or C++?
-Joe
Unread 12-01-2011, 14:41
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
2) Driver station
4) Netbeans plugins
Alexander,
Did you try the setup after transferring the parts and before updating the firmware/software? When it comes to designing complicated systems only change one (or as few as possible) thing(s) at a time before testing again. This may seem like it takes longer, but it's worth it. It's like writing all of your code for the year without testing it at the end. Test the components along the way and you're likely to end up with a fully functioning design.
Now aside from that, I've got nothing helpful . Sorry.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 12-01-2011, 15:21
-Joe
I assumed that the CAN wiring (and all the IDs) were fine because a test with BDC-COMM yielded good results, i.e. everything worked. I have not tried it in any other languages, when I get over to the school I'll hack together some C++ code. As a side note, is there a list of status codes and what they mean anywhere?
To Bryscus, we performed limited testing (running one Jag in position control mode) after the move but before the firmware/software updates, and it worked fine.
Thanks for all the help so far!
Unread 12-01-2011, 15:26
- Ron
Whoops, missed your post. Our code gives up without retrying--that's a good idea. I'll test that when I get there today.
Also, thanks for the hints, drakesword.
Unread 12-01-2011, 15:38
Check out the \src\com\ni\rio\NiRioStatus.java in the WPILibJ source. It has most of the errors that you're likely to run across in v25.
The next version of the cRIO image will have more custom error codes so it should be more clear what they are when you see the errors in the DS errors window.
-Joe
Unread 12-01-2011, 15:45
AKA: Ron R
At the risk of stating the obvious - of course give the loop a max number of retries....that way if there is something else going on and it never succeeds, you'll be able to see that rather than just continuing to try indefinitely.....
- Ron
Unread 12-01-2011, 18:33
AKA: Bryant
We would also advise that you run PWM cables to your jags so if the CANBUS goes down you can still control your motors. Just have a reduced functionality mode.
