Go to Post it is actually more important to understand and be able to clearly state the question than it is to know the answers. - GeeTwo [more]
Unread 12-01-2011, 15:47
dvader109's Avatar
dvader109 dvader109 is offline
FRC #3862
dvader109 is an unknown quantity at this point
Feeding VS. Throwing tubes into Play?
I was wondering what people thought the best way to put the tubes into play and what the advantages and disadvantages would be. Post Back
Unread 12-01-2011, 15:50
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Feeding VS. Throwing tubes into Play?
I know you're on a rookie team, but what do YOU think the advantages and disadvantages are? It will be helpful if you come up with your own answers and reasoning to discuss with users on CD instead of soliciting answers for such a general question.
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Personally, I think it's almost silly to throw a tube over the wall because you risk losing that tube, unless you throw it right in front of your robot (in the lane in front of you, par example.)
It really depends on where your robot is, in relation to the other robots on the field.
Summary: Only throw if you're guaranteed to retrieve it with your robot.
Just my $0.02 CDN.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 12-01-2011, 15:51
E.K PREADTOR E.K PREADTOR is offline
FRC #2242
E.K PREADTOR is an unknown quantity at this point
Thumbs up Re: Feeding VS. Throwing tubes into Play?
it would be best to feed the tubes. throwing them would result in them landing in a unwanted place and make it hard to drive the feild
Unread 12-01-2011, 15:52
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Neither. Feeding the robot to your tube means that your gripper/manipulator needs to be at a required height. Throwing the tubes onto the field increases your chance it will fall out out of the lane where an opponent can grab it, or fall into an odd position up against the field elements.
I would highly recommend dropping the tubes through the feeder on the ground. I did some testing at the field in Manchester and found that lightly dropping them onto the ground puts them in the same place in the lane each and every time nice and flat.
Those are my thoughts.
1058 PVC Pirates 2016 - xxxx
Unread 12-01-2011, 15:54
Gdkoopa's Avatar
Gdkoopa Gdkoopa is offline
AKA: Aric Lohrer
FRC #1742 (Shockwave)
Team Role: Student
Gdkoopa is an unknown quantity at this point
I think throwing the game pieces into play could have a major advantage in saving time by not having the robot come all the way back across the field to the feeder slot to retrieve a game piece. Of course their are issues such as picking it up, throwing it accurately and such. But if one were to really practice this tactic it could prove to be a definite time saving advantage.
Unread 12-01-2011, 15:56
dvader109's Avatar
FRC #3862
Thanks Everyone.
Unread 12-01-2011, 16:00
ttldomination's Avatar
Sunny
What about throwing the tube across the field? In '07, human players could easily hit the rack with a strong throw, likewise, I don't think it'll take too much to get the tube to the tubes a way past the half way mark.
- Sunny
1648: 2013-2014
5283: 2015
Unread 12-01-2011, 16:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
- Sunny
In 2007 there were red tubes for the red alliance, and blue tubes for the blue alliance. In this game either alliance can use pieces that are thrown onto the field. This is a big argument against throwing them.
Unread 12-01-2011, 16:04
Borntolose Borntolose is offline
AKA: Nadav Mailhot
FRC #1574 (Miscar)
Borntolose is an unknown quantity at this point
We haven't really done any tests with the logo pieces yet, but it seems to me that it would be very hard to throw them to your end of the field. By throwing the tubes you would probably end up helping the other alliance more unless you manage to throw the tube right to where your robot is.
Unread 12-01-2011, 16:14
ThirteenOfTwo's Avatar
ThirteenOfTwo ThirteenOfTwo is offline
College...
FRC #2438 (`Iobotics)
ThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to allThirteenOfTwo is a name known to all
Punching a tube through the slot can reliably get tubes all the way to the end of the lane without leaving them open for getting stolen. Shaves off a couple seconds.
Unread 12-01-2011, 16:59
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Throwing tubes will likely end up being situational... If you know the other alliance can't pick up tubes from the ground, go ahead and throw. If you know you can get it near your robot while no one from the other alliance is near by, go ahead and throw. if you're amazing enough to get it into the 7' protection zone on the other end of the field, go ahead and throw. Otherwise, punching it out the hole to get it to the end of the lane is going to be your best bet - it's closer to your robot, and the other team can't touch it.
Unread 12-01-2011, 21:40
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
I'm not really affiliated with any teams at the moment, so I can't say that this is or is not used by any teams I've worked with prior. I will say that an idea I had was to have a pole of sorts on the robot for the human player to toss a ring onto that then has a claw take it off in order to score while your driving to the other side of the field could save enough time for an extra tube every match if you had a reliable human player. Also, you wouldn't even have to take it off of the pole, if the pole was a part of your manipulator(say one part of the claw). I'm just kind of throwing the idea out there to see what others think of the feasibility of it.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 13-01-2011, 08:48
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
That would require one heck of a human player. If memory serves they'd have to hit the pole on the robot after throwing it OVER the player station wall.
Unread 13-01-2011, 18:15
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
also handing it to your bot over the wall like 111 did in 07 could prove to be a solid strategy. I think we will rarely see tubes be thrown to bots unless one alliance cant ground load
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
