Go to Post It is usually the simple things that get you. - Andy Brockway [more]
Unread 12-01-2011, 15:33
mechE131's Avatar
mechE131 mechE131 is offline
mechE131 is an unknown quantity at this point
Attaching to the pole
Hey Guys,
I was wondering how you guys were planning on sticking to the pole in order to climb it?
My team is using a small diameter piece of plexi as "torsion bar" spring with a series of arms to hug the pole.
Any other thoughts?
Unread 12-01-2011, 15:35
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Attaching to the pole
Drive wheel(s) and a cam mounted roller.
Unread 12-01-2011, 15:53
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
We've been throwing around magnets quite a bit.
Unread 12-01-2011, 16:00
mechE131's Avatar
Magnets can be tricky; you have to get the perfect magnet for your application and use an appropriate configuration. Not impossible, just tricky.
Unread 12-01-2011, 16:04
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
Be careful not to put an eye out.
Unread 12-01-2011, 16:06
mechE131's Avatar
lol
Unread 12-01-2011, 16:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'm personally going to suggest 2 wheels and a lever arm with the battery on it. As long as the leverage develops enough normal force to make the wheels grip, it's probably the lightest minibot you could possibly make. The effectiveness of this would depend on how much machining of aluminum bar/sheet the GDC is okay with, since it'd work best with custom wheels.
Unread 12-01-2011, 16:28
billbo911's Avatar
Agreed, but custom wheels are not on the allowed list. They must be "Tetrix components"
<R92> The following items are the only permitted materials for use on the MINIBOTS:
A. TETRIX components that are not
in violation of any other rules,
Unread 12-01-2011, 16:29
GaryVoshol's Avatar
Cogito ergo arbitro
But several raw materials are on the list; you could make wheels out of that.
(since 2004)
Unread 12-01-2011, 16:31
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
Can the wheels be modified?
If so you can use the non-slip pad, just cover the wheel with that.
Unread 12-01-2011, 18:40
DonRotolo's Avatar
Back to humble
FRC #0832
Is non-slip pad a Tetrix component? If not, I don't see it in <R92>
Unread 12-01-2011, 18:46
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
<R92-P>
Unread 12-01-2011, 18:47
WireFreaks2156's Avatar
WireFreaks2156 WireFreaks2156 is offline
.Keep it simple.
AKA: Jessica Hageman
FRC #2156 (WireFreaks)
Team Role: Team Spirit / Cheering
WireFreaks2156 is a jewel in the roughWireFreaks2156 is a jewel in the roughWireFreaks2156 is a jewel in the rough
my team was thinking of a mulan style pole climbing, a circular bot with wheels on the inside lining, the bot would grip around the pole and climb uo using the wheels, then at the top the wheels would be pushed out against the pole in order to stay up there, then released back when it has to come down
Unread 12-01-2011, 20:14
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I presented my idea with simplicity in mind. Less moving parts means a more robust robot. My idea was just have a one way opening "door", nothing fancy, but gets the job done right.
Unread 13-01-2011, 00:59
mechE131's Avatar
Their is almost no doubt that the most competitive minibots will use wheels to propel themselves up the pole. I wanted to discuss with some of the members of the forum methods of actually attaching to the pole.
This is a key element in any "on paper" design. This includes a detail free body diagram of all the forces, one of which being the force that keeps you attached to the pole. Inevitably, this force will also react with friction force and resultant force the most.
In other words, say you choose magnets to hold your minibot to the pole. You go one mcmastercarr.com and choose the strongest magnets you can find. All of a sudden you can hold 15 lbs. to the pole; the max possible weight of the minibot. But now you must create a large enough moment (torque for the layman) at the driving wheels to not only break free of the magnetic force, but also react against your weight (mass X accel.) and the friction force.
It may or may not work out so beautifully.
