Re: Power Distribution Module Wiring
Cuy,
The WAGO site has a tutorial on how to use these. It requires a WAGO tool or a small screw driver. The took is inserted in the upper part of the terminal and pushed into place or manipulated to open the contact. While you hold it open, you insert the stripped wire (5/8") and then while holding the wire in place, remove the tool. It takes some practice so don't be discouraged.
