Go to Post Teams should spend more time talking about how to avoid penalties during their strategy sessions. - Rob [more]
Unread 12-01-2011, 16:55
EROCK EROCK is offline
FRC #2450
EROCK is an unknown quantity at this point
Help! Tetrix Motor Dimension
Ok so we do not have an FTC program at our school and there for do not yet have access to a tetrix motor(they are on order). Does anyone have one and if so could they post the dimension of the motor/shaft so that I can start sketching it in SolidWorks?
Thanks
Unread 12-01-2011, 17:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Help! Tetrix Motor Dimension
Models from most Tetrix components are available on 3dcontentcentral.com. The motor is available there.
--Madison--
...down at the Ozdust!
Unread 12-01-2011, 18:13
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Also if your school is running the Education Edition 2010-2011, most of the Tetrix models in SolidWorks format are availble from the Design Library on the left hand side of the graphics window.
Select Design Library>SolidWorks Content> Robotics and then Ctrl-Click the Tetrix folder.
You will down load a zip file for most of the tetrix parts.
You can add this folder to your design library - under the Add button.
Then all the tetrix parts will be inside of SolidWorks.
Marie
Unread 12-01-2011, 20:59
FRC #2450
just found the designs... Thank you much!
