Go to Post Well, John V-Neun still has a little bit of hair. Maybe it'll be an astroturf field? - Amanda Morrison [more]
  #31   Spotlight this post!
Unread 11-01-2011, 23:11
Snowbotics's Avatar
Snowbotics Snowbotics is offline
FRC #0981
Snowbotics is an unknown quantity at this point
Re: Articulated arm vs Forklift style arm
Originally Posted by davidcone315 View Post
My team is considering using a vacuum to pick up the tubes instead of an arm, does anybody think that is a bad idea?
My team has personally experimented with suction in the 2007 game and we were met with great disappointment and in the end failure to that idea.
  #32   Spotlight this post!
Unread 11-01-2011, 23:17
Snowbotics's Avatar
FRC #0981
Originally Posted by JosephBurns35 View Post
i was thinking of doing a fork lift type arm but was wondering how important it would be to be able to pick the pieces of the ground. if it is important than the arm would have to be far more complex than i originally thought.
If you look earlier in this forum someone on I think the first page posted a link to some pictures of a 2008 robot with a fork lift that would solve that problem easily
  #33   Spotlight this post!
Unread 12-01-2011, 19:00
Furrah!! Furrah!! is offline
FRC #1425
Furrah!! is an unknown quantity at this point
Hey for everyone whose considering an arm, check the rule update! the 60"diameter has been changed to 84"!!
  #34   Spotlight this post!
Unread 12-01-2011, 19:24
Timmur Timmur is offline
FRC #3189
Timmur is an unknown quantity at this point
The problem with a vacuum is the power it will take and that you need to apply a complete suction to most of the surface for a hold. also if the intake of air is not completely covered that means less pressure and less of a grip. This competition calls for speed so there is going to be some bumping no matter what. That suction might not hold. If you still plan for all this and do vacuum successfully then i tip my hat to you. good luck to all this year!
  #35   Spotlight this post!
Unread 12-01-2011, 19:46
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Originally Posted by drakesword View Post
The biggest con with an arm this year is the 60' rule!
60" is only the starting configuration after the match has started you can go as high as you want
  #36   Spotlight this post!
Unread 12-01-2011, 19:59
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
This entire week my team and i have been designing and searching for ideas just like most everyone but we've found that watching the championship games from 2007 show some great bots with incredible designs that use the articulated arm with a claw and the forklift idea that was mentioned. We've pretty much settled on the arm idea but engineered our own claw. My suggestions would be to watch some videos and study up a bit. Also with the new updates that have been set into play could possibly help! Like for instance the 84' diameter now no longer 60'. So it might be somethin to consider maybe! Best of Luck to all!
RHS Senior 2011
  #37   Spotlight this post!
Unread 13-01-2011, 23:07
TheGreatPhil TheGreatPhil is offline
FRC #2264
TheGreatPhil is an unknown quantity at this point
Originally Posted by Tom Ore View Post
We're thinking of using static electricity to pick up the tubes. The programmers are trying to figure out how to make the robot shuffle it's feet on the carpet.
Good luck with that, if you really want to go with static electricity I'd recommend using capacitors to build up charge.
  #38   Spotlight this post!
Unread 13-01-2011, 23:21
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Team 2502 has a mentor that is a salesman at a pneumatics company and deals with all sorts of pneumatics and industrial extruded materials.
He brought in his kit of vacuum products with all assortment of cups (standard to weird shaped ones) and all sorts of valves and vacuum modules and items of that nature and we tried everything. It held on to the tubes REALLY well and even held tightly when shook... But once we put our hand to one of the father places of the tube and pushed it, it just popped right off.
Also, air consumption, we thought, would be an issue to keep the seal tight for the entire 2 minutes.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
  #39   Spotlight this post!
Unread 13-01-2011, 23:26
pfreivald's Avatar
AKA: Patrick Freivald
This is generally my objection to pneumatics.
If you are repeating the process over and over, you're chewing through your batteries via the compressor. If you're not, then why are you including pneumatics when a motor or servo can do the same job?
I long for the day that the electric solenoid -- so darn useful in industry -- is finally allowed in FIRST.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #40   Spotlight this post!
Unread 13-01-2011, 23:28
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Originally Posted by pfreivald View Post
What if one were to design a forklift that could still pick up things off the floor, over the top of the bumpers, without use of a motor to articulate their grabber?
Hmmm...
Really?
Hmm.
I think we need to setup a party between our teams at your shop sometime after you build it...
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
  #41   Spotlight this post!
Unread 13-01-2011, 23:34
pfreivald's Avatar
Originally Posted by Alex Cormier View Post
Really?
Hmm.
Nevermind... We came up with something even better.
Team 1551
I write books, too!
  #42   Spotlight this post!
Unread 14-01-2011, 01:22
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Arm pros:
simpler
more robust
lighter
Lift pros:
easier to score on the pegs
can raise lift in safe zone without having to leave the zone
As a team that did the lift back in 05. I can say that it takes a lot of upkeep and in many ways is not worth it. on the other hand that was one of our best robots all time. I couldn't find any pictures of the lift but if I do I'll post them
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
  #43   Spotlight this post!
Unread 14-01-2011, 02:09
foote stepped in
AKA: E. Foote
FRC #0868
Here's my teams 'bot from 2007. You'll want to watch from about :37-1:27
http://video.google.com/videoplay?do...5109075900959#
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #44   Spotlight this post!
Unread 16-01-2011, 16:18
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
I think he was joking
  #45   Spotlight this post!
Unread 16-01-2011, 16:36
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Really?
Hmm.
Not to crash your party, but since we are doing that, I can't wait to see how you do it at FLR!
