Go to Post The 4-wheel drive systems bounce around like Mexican jumping beans. It is quite fun to watch. - Warren Boudreau [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-01-2011, 19:14
Eagletron Eagletron is offline
FRC #3675 (Eagletrons)
Team Role: RoboCoach
Eagletron is an unknown quantity at this point
Male Adapter for Window Motor (left/right)
Does anyone know where we can find the male adapter for the Window Motor (left/right). It wasn't included in the Rookie KOP's.
Unread 12-01-2011, 19:41
Re: Male Adapter for Window Motor (left/right)
You've got 20 minutes left for your Main Contact to tell FIRST through TIMS, that they are missing from your Kit.
Unread 12-01-2011, 19:52
Mark, I don't think the male adapter is in the original KOP's. We already did inventory and everything is accounted for.
Unread 12-01-2011, 19:55
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
If I recall correctly, there hasn't been an adapter in the KOP for the window motors or many of the motors.
What I have done in the past is take a pair of plier cutters and chip away at the plastic to get the metal leads to have the electrical team solder wires onto them. Or you could use a small hand saw and do it that way carefully.
Hope that helps.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 12-01-2011, 20:11
I thought you meant the mechanical coupling for the output.
If you meant the electrical connector, then what Alex said.
We don't usually remove the plastic cover, but we do solder and heat shrink the connection.
Unread 13-01-2011, 00:10
Smile Re: Male Adapter for Window Motor (left/right)
thank you both for replying so quickly! It helped. Still, wonder "why" the KOP's didn't include the adapter? Oh well, we'll proceed accordingly.
Thanks!
Unread 13-01-2011, 20:32
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
imac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of light
If you want to actually use a connector then use a Delphi 280 Connector, Delphi model number 12129487. This can be found on Mouser Electronics with this part number: 829-12129487. Delphi lists this connector as being used typically in Window Lift Motors. My team used this connector last year and they fit perfectly in the motor, and wouldn't allow for accidental disconnection.
The terminals for the connector vary depending upon the wire size you use, the complete listing of the terminals can be found here under the "Related Parts" tab. Then take the Delphi part number and search Mouser for it to find the terminals on there.
Hope this helps.
- Ian McInerney
Alumni & Mentor, Team 2022 Titan Robotics
Junior, Iowa State University majoring in Electrical Engineering
