Go to Post What a great organization! - HoltDan [more]
Unread 12-01-2011, 21:30
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Programming Logitech Gamepad F310
Originally Posted by ksanger View Post
Thanks for this thread. I assume this means that If our driver station is running on a Windows 7 laptop and Win7 sees the gamepad and loads the drivers then the wpilibj will see the controllers as a Joystick.? Or is it more like XP and we have to find and install a .dll for the gamepad we choose?
The Driverstation should identify the joystick if the computer has been able to find it. If it hasn't post here and I would be happy to assist you.
Unread 12-01-2011, 23:32
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
I find it good to use the getRawAxis() command. It lets you use all four or five axis from a game controller (two for each stick, one for the triggers on the xbox 360 controllers my team used last year) easily, just by specifying the number, which is relatively easy to determine via trial and error.
EDIT: For buttons, I use getRawButton() in the same way (give it the number of the button). One issue I had was that the D pad wouldn't work, but I think thats because it is read as a 2D position, not a single axis, or something like that.
