Re: Scoring Pegs
Thank you so much, to be honest I totally forgot about even searching it. Thank you
Re: Scoring Pegs
Outer posts: 30 inches, 67 inches, 104 inches
Middle post: 38 inches, 75 inches, 112 inches Ranging from 2.5ft to 9-1/3ft, That's going to be a fun challenge! |
Re: Scoring Pegs
To determine once and for all what the peg heights are, go to this link:
http://www.usfirst.org/roboticsprogr....aspx?id=18763 Download the Game Specific drawings for all the playing elements on this year's field. Specifically, look at drawings GE-11000 through GE-11005. From these you can determine measurements from the 11 gauge steel base plate that sits on the floor up to the bottom of the pegs, or to the center of the end disks which are welded tangent to the bottom of each peg's pipe, or to the top of this disc. Since I don't know how you will plan on aiming at the pegs, I won't publish actual dimensions here, but you can easily calculate them. Plans are also on this site for team-built pipes made from PVC plastic pipe. Be careful when you make the pipes out of plastic. Not all tee-fittings are the same size, and pipe doesn't always bottom out when glued into the tee-fittings, so be sure to measure the finished products when you make them. |
Re: Scoring Pegs
Re: Scoring Pegs
With that in mind, if you have gone through the detective work / chore of doing the arithmetic, and of factoring in all of the additions created by the baseplates and boxes the poles rest in, how about sharing the result with us? Listing a summary of the various parts' contributions would set a useful answer apart from the ones that simply list 6 numbers. Blake PS: I'm not above suggesting that lazy folks should read the rules and other docs instead of asking the rest of the world to do their homework for them; but I think this falls into a different category. |
