Go to Post People don't lead because they are chosen to lead; they are chosen to lead because they lead. - EricH [more]
Unread 12-01-2011, 21:08
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Best way to control the mechanum wheels
So I've heard that it's easier to control the robot with four mechunum wheels with an x-box controller. Is this true? If it is true how do you program that, because I'm our teams programmer?
Unread 12-01-2011, 21:16
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Best way to control the mechanum wheels
First, before touching any code, write down everything on paper. Now I personally have no experience with mechanum drive, but I do have lots of experiences when the robot goes haywire because I used the wrong operation or something silly like that. Always double check before hitting "run".
I would say if the X axis (or what ever you are trying to control the strafing with) is past a certain point then switch to "strafing" mode. Then make the wheels rotate based on the x axis. Its quiet simple IMHO. I assume you would have the same code for the regular 4, 6, 8 wheel drive then tag on the strafing.
Unread 12-01-2011, 21:22
slow down there i forgot to say this our first year with mecanum wheels should we just stick to the basics with the joysticks?
Unread 12-01-2011, 21:25
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
You should use a joystick with a twist axis. Forward and back make the robot go forward and back, side to side makes it strafe, and twisting the joystick turns the robot. I have no idea about the programming though, I do mechanical/CAD.
Go REX!!!
Unread 12-01-2011, 21:26
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
No, I say go for it bro. If you do not have the resources to build a prototype, I can make a software simulator for you. It won't be a robot driving on screen, but I can do motors on screen displaying its PWMs. First get the regular 4 wheel drive working with 1 joystick (the xbox controller in this case) then I will assist you with the mechanum drive. From the looks of it, its just the 4 wheel arcade with some extra
Unread 12-01-2011, 21:27
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
There are enough people here that do have experience with mechanum drive and have learned from those experiences. As it is with rules questions, only post when you are positive you are correct opposed to what you think is right. (I try to practice this and if you notice, I rarely, if ever, post in technical threads )
PS: for all I know, what you said was 100% correct and if so, I apologize.
Unread 12-01-2011, 21:28
And you're starting during build?
Stick to the joysticks. There's prewritten code around somewhere; you would of course have to find it in your favorite language and tweak it for your robot.
I don't recommend doing mecanum in the six weeks if you haven't done it before; if you do it that way, KISS is a MUST. Start with stuff that's already out there.
David, you're close to right about the method, except that you forgot one thing: 4 independent motors vs 2 pairs of 2 motors. 2 pairs of 2 motors, you can Y-cable. 4 independent, it's a lot harder to Y-cable for some reason. Also use caution: Should you go to fallback (mecanum goes to 4WD rather easily), make sure you comment out the strafing--Alan Anderson of FRC45 found that out the hard way.
You could also do a complete directional program. That might be a bit harder.
Unread 12-01-2011, 21:39
My team really wants to do mecanum wheels... Anyone got any sample code for two joysticks+mecanum wheels?
Unread 12-01-2011, 23:00
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
This is my 2nd year programming and last year we had a basic 4 wheel drive. For this year the team has chosen to go with mecanum. I'm using labview. It would be awesome if someone could teach me the programming behind mecanum drive.
~Team 1529 Cybercards~
Unread 12-01-2011, 23:04
Im using c++ anyone got any good libraries?
Unread 12-01-2011, 23:05
KHall KHall is offline
KHall - 2171 Crown Point IN
FRC #2171 (RoboDogs)
KHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud ofKHall has much to be proud of
Which develpment environment are you planning to use?
If its LabView, the VIs are all supplied. You'll have to do some problem solving to convert the joystick's output (or any other kind of steering device) to the inputs that the mechanum VI requires.
I can vouch for the LabView VI. We used it last year, it works great. And we've done mechanum wheels 3 of the last 5 years. Like anything else, there are tradeoffs to consider.
Keith Hall
Mentor FRC 2171, FLL 1528
Unread 12-01-2011, 23:07
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
The only library allowed is the WPILib.
pfreivald's Avatar
AKA: Patrick Freivald
Last year we used mecanum to great success, using two joysticks. One joystick controlled movement direction, and the other controlled rotation -- exactly like a 1st person shooter played on Xbox.
While it wasn't an Xbox controller, our driver could think of it as one, and he had an intuitive knack for it very quickly.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 12-01-2011, 23:10
So it's not hard to do it in c++?
Unread 12-01-2011, 23:12
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
No not at all, the mechanum drive would only take 5 lines MAX. (excluding the header file and PWM regulation)
