Go to Post Are we really at the point where the only useful thing we can discuss is Dean's choice in timekeeping apparel? The man has a watch. He uses it to tell time. Do we really care how much it is worth, or who made it? I would be much more interested in what he does, not what he wears. - dlavery [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 13-01-2011, 01:08
Daniel Krastev's Avatar
Daniel Krastev Daniel Krastev is offline
AKA: D-Back
FRC #3017 (Project Genesis)
Daniel Krastev is on a distinguished road
HELP Elevator/Lift!!!
Our team has decided on an elevator/ lift mechanism to pick up tubes from the feeder slot. We want to have something like a an aluminum L- shaped hook that rides up and down an upright Aluminum Drawer rail near the front of our robot.
We have also decided that in order to reach the middle and high pegs, we will need to have the hook ride up the full 58-60", and then have that Aluminum Drawer ride up another aluminum drawer in order to extend another 58-60".
We want to use two pulleys with two separate motors (One for the elevator/ hook for the first 60" and the other pulley for the middle aluminum drawer rail for the other 60")
I need some help on implementing this idea...what kind of parts would I need? How exactly can I make the elevator/ hook ride up the middle aluminum drawer rail, etc. Any advice will be HEAVILY appreciated! Thank you all very much!
This picture is something along the lines of what we want to do...but without the "pneumatic wrist"
http://www.chiefdelphi.com/forums/at...4&d=1294553422
Unread 13-01-2011, 10:13
mechE131's Avatar
mechE131 mechE131 is offline
mechE131 is an unknown quantity at this point
Re: HELP Elevator/Lift!!!
that stuff that robot in the link uses is called 80/20. Google it and check it out. I would also reccomend looking at team robots from past games, especially from 2008. I remember a lot of fork lifts back then.
Unread 13-01-2011, 10:26
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Here are some robot examples of elevators:
http://dulaneyrobotics.com/component...hesapeake3.jpg
http://dulaneyrobotics.com/component...ld/build-8.jpg
There are some different ways you could go. A wire rope spool to pull the elevator, chain on sprockets mounted to the sliders.
Go REX!!!
Unread 13-01-2011, 10:30
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The elevator design your referring to has two moving stages... and believe it or not, you can power both stages with a single motor! We built a similar elevator in 2008, and it looks like the team is leaning that direction again.
http://www.chiefdelphi.com/media/photos/30267
http://www.chiefdelphi.com/media/photos/35975
http://www.chiefdelphi.com/media/photos/35974
In order to power it with just one motor, you need to think through how the pulley's and the cable that lifts it moves. It starts near the bottom, and runs up to a pulley on a stationary cross member (this pulley never moves). From there, it runs down to a pulley on the outer-most moving stage. If you were to just tie it off here, it would life that stage up. But, since you go around a pulley there, you can send that up to a pulley at the top of the same stage. The distance between these two pulleys is fixed, since they are part of the same stage. From there, you run it down to the inner-most moving stage, and tie it off.
When you end up powering the motor, the inner-most (smallest) stage moves first. When it gets to the top, then the middle (the outermost moving) stage moves. In the end, the whole thing extends!
Attached is a quick diagram of how the cable runs work. The blue is the cable, and the gray is each stage. White circles for the pulleys, a big black circle where the cable gets tied off.
Unread 13-01-2011, 10:40
IFB662 IFB662 is offline
FRC #0662
IFB662 is on a distinguished road
Lightbulb Re: HELP Elevator/Lift!!!
This is very interesting my team has always used pneumatics for our elevators but are considering something with pulleys for this year.
THE ONE THE ONLY ILLUSTRIOUS FILE BOY
Unread 13-01-2011, 10:55
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
what did you use for bearings for the inner most stage riding on the outer stage?
FRC78: 2010-Present
FRC121: 2002-2009
Unread 13-01-2011, 11:18
I'm not sure what the exact product was, but we used the same items for each stage. We built small brackets that could hold the rollers/bearings outside the adjacent stage, holding the whole thing together. You can see them about 2/3 of the way up the picture here:
The rollers are white, and duplicated front and back. The innermost stage has the rollers attached to itself on both top and bottom to hold it inside the middle stage, while the middle stage only has rollers attached to the bottom (extending out to wrap around the outer, stationary stage), while the outer stage has rollers at the top to wrap around the middle stage. This way, the inner stage remains completely within the middle stage at all times, while the wheels at the bottom of the middle stage approach the wheels from the top of the outer stage, holding it in place as the stage raises above the outer stage.
Unread 13-01-2011, 11:56
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Lots of pics here, nicely organized: http://www.firstroboticscanada.org/site/node/96
Unread 13-01-2011, 12:03
Bsteckler's Avatar
Bsteckler Bsteckler is offline
Resident computer tech
FRC #2402 (JamesMonroebotics)
Bsteckler has a spectacular aura aboutBsteckler has a spectacular aura about
Here's one that our team made in 2008. The video is not excellent quality, however.
http://www.youtube.com/watch?v=LMIwLd9GLh0
"Don't try anything you are about to see us do at home, ever"
-The Mythbusters
2402 scores points.
Unread 13-01-2011, 12:23
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
http://d1pytrrjwm20z9.cloudfront.net...atorDesign.pdf
This presentation by Andy Baker is VERY HELPFUL. Talks in general about manipulator designs and goes a little into the pro/cons and basic designs of each, including the elevator lift!
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
