| Thread Tools |
Rating:
Display Modes |
#46
Re: Minibot climb rate
Light switch also seems vague.
http://www.google.com/imgres?imgurl=... t:429,r:7,s:0 http://t3.gstatic.com/images?q=tbn:A...ZNCpHRGzXlZwFe The latter seems more useful, but seems less "standard." How much can we take the switch apart? If all we need is the mechanism, can we tear away at the innards? |
#47
You haven't even approached non-standard light switches. I'm busy pondering whether they think three way light switches are "common" or not. Cause it sure would be nice to reverse those motors.
#48
Thank! |
#49
80T Weight = 46.00 g (in packaging) - checked last night
#50
why would you want to be able to run them backwards?
#52
Makes for easy/gentle retrieval if you allow your robot to climb back down to the base to patiently await you!
#53
What JB said. If I can put a lightweight system on there to reverse the motors, I don't have to put on a robust retrieval system. Nor do we have to cart a reachin' stick out on the field after every match to get our minibot down. Mind you, we don't have our kit yet. The motors might backdrive quick enough that opening the circuit is adequate. I'd just like to keep my options open.
#54
#55
You don't think the Field Staff will be using them as benches during long timeouts?
#57
Yeah, standing on the base will probably get a team member a good dope slap from a ref.
#58
Added the FTC motor specs, some efficiency losses and Normal force effects. Robodox 599 Numerology 3x3x3x3x3.3 minibot @ .8 efficiency (wheel_dia_in) x (gear_ratio) x (time_to_climb) x (speed_fps)x(weight_lbs) ![]() Last edited by vamfun : 16-01-2011 at 23:06. |
#60
My house has several 3-way switches so mounted, I bought them at Lowes, so they're OK to use. |
