Go to Post It's not about a team having lots of money to spend to travel the world to share FIRST but how the team draws the world into their FIRST experience. - Steve W [more]
Unread 12-01-2011, 23:55
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Question Inventor - shorten chassis segments?
OK, I'm sure this is a noob question, but I'm very new to Inventor. Like 3 hours new. I'm pretty good at teaching myself, and have been through some tutorials already.
I've made a new file in which I've placed a bunch of C-Base chassis channel segments, along with the corner connector things. I've got it all constrained together. The thing makes a big square though, of course, since all the chassis bars are the same length. I want to shorten the two horizontal bars so I end up with a "long wheel base" rectangular shape.
I've been digging all through everywhere trying to figure out how to isolate one component (or these two bars in this case) and simply change the length of it. I want to make it like 10" shorter or something.
How do I do this?
FRC 2656 | FTC 5526 | VEX 9656
Unread 13-01-2011, 00:57
Bmarquez Bmarquez is offline
FRC #3143 (Extreme Exotic Fire Breathing Rubber Duckies)
Bmarquez is an unknown quantity at this point
Re: Inventor - shorten chassis segments?
Its quite alright to be new to inventor but the problem you have can be solved albeit slightly mundane.
1. Open up the parts file for the chassis rail in its normal drawing (not as an assembly)
2. right click one of the flat, long faces of it (IE, not the end, though it can be done, lets keep it simple =D )
3. click "start sketch" (or some similar command, it depends on your inventor version)
4. Draw a simple box over the section you want to cut off, be aware that you keep your spacing as autodesk does EXACTLY what you tell it to, so you might need to cut off 9.5 or 10.5 inches to get the holes lined up properly.
5. Finish the sketch to enter into the modeling commands.
6. Click Extrude and select your square, use an appropriate depth to get rid of the bar entirely.
7. Before you click through on the extrude click the second box under the section where you put in your depth, this should tell it to subtract rather then add. Youll know you did this right if the outline of your box is in red as you look at it from an angle.
8. Click okay and voila! your C-channel has been cut
9. go to file, Save as.. and save it as a DIFFERENT file, IE C-channel_short_bar *
* the name doesnt matter, but it MUST be different or else you just changed the original part and will have to re download it from FIRST or your parts backup.
10. Rebuild/re-mate your assembly with your new part.
Hope i helped!!
Unread 13-01-2011, 01:12
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
Instead of cutting it shorter I just right clicked on "extrusion 1" on the left, selected "edit feature", adjusted the length to what I needed and clicked OK.
Then I deleted hole 1 and hole 2 to clean it up a bit.
Unread 13-01-2011, 08:15
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
This is a better method. If I remember correctly the "C" channels are drawn as sheet metal parts that at folded much as they are in real life. Its a much better practice to simply edit the original extrusion or sheet metal feature, rather than add additional sketches or features to the part.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 13-01-2011, 11:46
Domtech's Avatar
I Do Everything
AKA: Dominic
They are extruded parts not sheet metal parts (in inventor, the reverse is true in reality)
Unread 13-01-2011, 14:01
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
If you want to maintain an accurate BOM while shortening the rail, I recommend that you add the C-Base Rail to an assembly (presumably called Rail-Short or Rail - Long) and then add an extrusion(s) to cut the rail. You would then make a print of Rail-Short and flag out the use of the C-Base Rail in its construction. Save-As disconnects the new geometry from the old which may not be desirable. Also, if you add information to the AM rail at some point, like a hole or some iProperties (cost data) then none of the Save-As geometry will update, but all the stuff modified at assembly will.
Don't forget to pay attention to where the holes are in the AM rail are as you shorten it; it may be beneficial to take some material off both ends so that the hole patterns remain centered.
Mark
Brick walls are for other people. - Randy Pausch
Unread 13-01-2011, 14:56
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
I assume many people use the Kit/Parts files provided by Autodesk or AndyMark (whichever creates them). Everyone should have the same issue then, of having to shorten the C-channel to make anything aside from a square. Again, being a novice, this seems difficult.
I'm getting the hang of constraining things, but I don't know about trying to modify already-created parts. I wonder if any teams have Inventor files available containing the shortened bars for a "long wheel base" style machine. I'll look around.
Anyways, thanks to everyone that's replied so far. Accurate, detailed, and quick answers are why I always come to Chief Delphi first. Thanks!
Unread 20-01-2011, 15:19
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Great discussion.
I modeled the chassis parts so you can edit a chassis section to whatever size you need.
My preference is using the Edit Feature option on the appropriate extruded feature.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 08-02-2012, 10:59
mglucido mglucido is offline
FRC #2838
mglucido is an unknown quantity at this point
How do I avoid making the shortened channel affect all similar parts? Thx!
Unread 08-02-2012, 11:28
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Do a "Save As" to the modified part, parts with the same name will be the same in your assemblies. You can do a "Replace Part" in the assembly once you have the new file created.
Unread 08-02-2012, 14:14
FRC #2838
Thx. EZ! ... still new to this
Unread 10-02-2012, 14:16
Looks like you got good advice on how to modify the chassis parts. Let me know if you have any other questions.
Phil Dollan
Autodesk Inc.
