Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Unread 13-01-2011, 12:12
Team3337_mentor's Avatar
Team3337_mentor Team3337_mentor is offline
AKA: Amanda Salom
FRC #6659 (Cougar Robotics)
Team3337_mentor is an unknown quantity at this point
Exclamation Manual Arena Section Specifications and Constructions Drawings
Hi,
We where looking at Section 2 on the manual - THE ARENA, specifically on Page 5, concerning 2.2.3 The SCORING GRID dimensions. We are really confused on the distances between one SCORING PEG and another. I was wondering if there is a drawing of specifications and construction of the SCORING GRID. If there is, can it be found in either of the links stated on Page 2 of the ARENA manual, in paragraph 3.
Also, we were reading sections 1 and 2, where they talk about the distances of the field areas. In section 2, it says that the feeding slot walls are 4'6" ft, and that the lane zone is 4'3", so my question is, how come the width of the scoring zone and the alliance stations are both 18' and the feeding slot walls and lane zones have different width.
Alliance station dimensions:
4'6" + 18' + 4'6" = 27'
Game field (Lane zones and scoring zone)
4'3" + 18' + 4'3" = 26'6"
Which width should I go with? the 4'3" to make sure the robot won't have any problems concerning walls?
Specifications and construction details of the ARENA
www.usfirst.org/frc/2011/officialdrawings.html
Team drawings
www.usfirst.org/frc/2011/teamdrawings.html
If so, both links are broken. I receive an error message for both links that states that the Page Cannot be Found and further down on the same web page it gives a second error that says HTTP 404 - File not found
Amanda Salom
FRC 6659 Cougar Robotics
Unread 13-01-2011, 12:17
Re: Manual Arena Section Specifications and Constructions Drawings
Yes, there are drawings. They are located at http://www.usfirst.org/roboticsprogr....aspx?id=18763
Under normal circumstances, you go with whatever the drawings say. The drawings are the final authority in terms of what the dimensions are supposed to be.
Unread 13-01-2011, 12:53
AKA: Amanda Salom
Thank so so much EricH.
Good luck
Amanda Salom
