Go to Post We don't use fancy tools like that, but we might need some wood glue or something :) - MrForbes [more]
Unread 12-01-2011, 15:24
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
6in or 8in?
we are building a 6WD and were trying to decide what wheels to use, the 8in rubber KoP wheels or 6in placation?
Unread 12-01-2011, 15:32
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Re: 6in or 8in?
Our team usually goes with 8" wheels, not the KoP ones, though. Kind of depends on what gear ratio you are going with and how fast you want to go. It also depends a lot on the material. We always go with a fairly soft rubber for maximum traction.
Unread 12-01-2011, 22:15
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
Re: 6in or 8in?
It's ultimately going to come down to what you're wanting your drive system to do. 6" and 8" wheels are going to require slightly different gearing and are going to have somewhat different torque and speed outputs. In addition, the plaction wheels are most likely going to have a higher coefficient of friction than the KoP wheels, though I haven't tested this so don't quote me for truth on that. I would certainly believe that the softer rubber on a plaction is going to have more grip than the harder rubber of the kit wheels, though.
If you don't mind doing a bit of reading, I would recommend this thread discussing the differences of different wheel diameters. They go a bit more in depth than I have here
Unread 13-01-2011, 13:18
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: 6in or 8in?
Just to warn you, the KOP wheels are somewhat low traction
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 13-01-2011, 13:20
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
Re: 6in or 8in?
4 in wheels are the best for this game, because there are no obsticals, you need a low center of gravity and you need traction. Thats why the best wheels are 4in Plaction wheels.
Unread 13-01-2011, 13:25
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: 6in or 8in?
Thats what I was about to say, 4 inch wheels. The kit gearboxes are geared pretty fast, so smaller wheels make better use of that speed.
Go REX!!!
Unread 13-01-2011, 13:41
AdamHeard's Avatar
Lead Mentor
Re: 6in or 8in?
For us, the question is always, "what is the smallest wheel we can safely run?".
This year, it's 4".
Andymark has great 4" wheels for cheap that will give you traction with the best of teams.
I recommended the 4" plaction wheels for a dead axle setup (the bearing has wheels in it and rotates on a shaft, and the wheel is directly driven by an attached sprocket), and the 4" performance wheels for a live axle setup (wheel driven by hexed or keyed hub).
The lower wheels make it way easier to get a low CG, among many other benefits.
Unread 13-01-2011, 13:48
AKA: Michael Amoun
Re: 6in or 8in?
Thats exactly what we are doing! you read my mind!
Unread 13-01-2011, 13:51
Chris is me's Avatar
AKA: Pinecone
Re: 6in or 8in?
Our CG as of now is under 2 inches from the floor. Small wheels are the best!
ignore that we don't have a manipulator yet, just for a second...
Unread 13-01-2011, 14:19
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: 6in or 8in?
We're fans of 4" wheels as well.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 13-01-2011, 14:29
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: 6in or 8in?
As many have mentioned it all comes out in the wash depending on gearing.
The KoP wheels have a coefficient of friction of 0.9, compared to 1.2/1.3 for the plaction wheels with wedgetop/roughtop tread.
I am a fan of keeping the CG low, but for the purposes of high-speed impacts you want to keep your CG inside the bumper zone, which happens to be pretty darn low this year: 1" to 7" IIRC.
FWIW we are planning on using 6wd with 6" plaction in the middle where most of the grip is generated, and 2007 FIRST wheels on the corners (you can buy them from AM). They are a softer rubber than the 2011 KoP wheel so they have a CoF of 1.
Unread 13-01-2011, 14:30
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: 6in or 8in?
We originally tried to design for 3" Colson wheels to eliminate a gearbox stage, but are going with 4" wheels to aid ground clearance.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-01-2011, 11:49
AKA: Michael Amoun
Re: 6in or 8in?
For the 4in plaction wheels, would you go with roughtop or wedgetop tread?
Unread 17-01-2011, 11:52
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: 6in or 8in?
AndyMark quotes a coefficient of friction of 1.2 for the wedge-top and 1.3 for the rough-top. I do not know if there are other advantages to either though.
Unread 17-01-2011, 12:01
AKA: Michael Amoun
Re: 6in or 8in?
So which of the two treads would you use, on your wheels?
