Go to Post This may not be Battlebots but it sure isn't Pretty Pretty Princess Bots. - Andrew Schreiber [more]
Unread 12-01-2011, 21:42
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Mecanum Newbie
On 810, we direct drive our mecanum wheels off of BaneBots P80 planetary gearboxes driven by a single CIM motor.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 12-01-2011, 21:53
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Re: Mecanum Newbie
Last year we direct-drove 8" mecanums off of toughbox nanos with their standard gearing.
Unread 12-01-2011, 21:59
NyCityKId's Avatar
NyCityKId NyCityKId is offline
That Weird Kid
AKA: Andre Dunkley
FRC #1601 (Quantum Samurai)
NyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to beholdNyCityKId is a splendid one to behold
Send a message via AIM to NyCityKId
Re: Mecanum Newbie
My team wants to go with mecanum/omni this year also. no one can really tell you what gearbox is better. it comes down to your robot and what you want to do with it. i would have to double check but i think the cimple gearbox and the tough box both use the same gear ratios. so mechanically it wouldnt make a difference. my team is personally going to use the GEM 2 stage (maybe 3 stage?) gear box if we decide to go with mecanum/omni.
Unread 13-01-2011, 11:53
Jester Jester is offline
Labview Maniac
AKA: Cody Ripley
FRC #3144 (Krypto-Knights)
Jester is an unknown quantity at this point
Re: Mecanum Newbie
No toughboxes are 15:1 i believe, whereas cimples are something like 4.8:1
Unread 13-01-2011, 12:58
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: Mecanum Newbie
Last year Team 967 used 8" mecanums directly driven with regular 12.75:1 toughboxes. We're going to do something similar again (we see no reason not to use Nanos this year), because it was nice to save some weight (no chains) and some time (no chains). It was a pretty fast drive. At its full competition weight, it needed a bit of a running start to get up the 45 degree ramps last year, so we would have geared it down a little bit for last year's game if we had it to do over again. But this year has a flat field, so we are going with the same thing.
You would not want to directly drive 8" mecanums with 4.67:1 Cimple boxes. It would be interesting to see how much you can push the speed beyond the standard 12.75 ratio, though.
Unread 13-01-2011, 13:26
Nafez Nafez is offline
FRC #1510
Nafez will become famous soon enough
Re: Mecanum Newbie
i would personally go with the old touch boxes(or some other transmission with a higher ratio) because they give more torque and that's needed when using a mechanum drive. as far as chaining or direct drive, my experience has made me go for the direct drive so you don't have to deal with chain and since this game isn't going to be terribly aggressive, i wouldn't worry about bending an axle. 1510 is going for a direct drive anyways.
Unread 13-01-2011, 22:58
pfreivald's Avatar
AKA: Patrick Freivald
Re: Mecanum Newbie
What gives you the impression that this game won't be terrible aggressive?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
