Go to Post We should all just be humble, courteous, and act like gentlemen (or ladies) on these forums, and not fill it with yakking about who's drive train is better. - Veselin Kolev [more]
Unread 13-01-2011, 15:11
bkeinath bkeinath is offline
FRC #3534
bkeinath is an unknown quantity at this point
Is there a pre-built labView program for rookie teams?
Hello,
I went to a talk/seminar on LabView. The rep from NI mentioned there was a pre-built/default program that rookie teams can use. (It has a big "finish" button on the front panel). Did I misunderstand him or is this located somewhere? If so, where do I find it?
Thank you.
Unread 13-01-2011, 15:19
Re: Is there a pre-built labView program for rookie teams?
That's the default Framework that comes with the LabVIEW installation.
Start LabVIEW
Under "New" select FRC cRIO Robot Project
In the popup window give it a new name
Change the cRIO IP address to match your team number
Select Robot Framework
Select Finish
and you'll have your default project that does Arcade drive off one joystick and two motor controllers plugged into PWM 1 & 2.
Unread 13-01-2011, 15:47
FRC #3534
I clicked on new....and saw several projects...however I do not see anything that says frc crio project....
Unread 13-01-2011, 16:04
This is the one I mean, where I've marked the screen in blue, click on that.
Unread 13-01-2011, 16:16
Your LabVIEW installation might not have fully succeeded, or you might not have run the required LabVIEW and Utilities updates. You know where to find the updates, right?
Unread 13-01-2011, 16:17
FRC #3534
That option does not show up on my computer. Perhaps the software was not installed correctly.....is there a way to get this...or do I need to reinstall?
Unread 13-01-2011, 16:33
Did you apply the LabVIEW software update Alan refers to?
You do that after using the LabVIEW installation DVD.
Ther's a link in my signature where you can get it.
You can run the LabVIEW installer and update again and it's smart enough to add anything you might have missed.
Unread 13-01-2011, 16:59
torihoelscher's Avatar
torihoelscher torihoelscher is offline
Wow I feel old
AKA: Princess Leia
torihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant future
Send a message via AIM to torihoelscher
http://usfirst.org/roboticsprograms/....aspx?id=18758
Click and it should give you the locations with the updates. I had the same issue and I had to redo everything so to avoid it, you must click on the URL and download the updates.
http://joule.ni.com/nidu/cds/view/p/id/2262
here is the link to one download
http://joule.ni.com/nidu/cds/view/p/id/2263
another one.
http://joule.ni.com/nidu/cds/view/p/id/2261
last one
extract and run the app.
Good luck and may the force be with you!!!
Tori Hoelscher
FLL
FTC
FRC
"May the [mass x acceleration] be with you"
"Aren't you a little short to be a storm trooper?"
Alumni of Team 79 Krunch.
Unread 13-01-2011, 20:33
Here's what the LabVIEW startup screen looks like right off the Install disk, if you have NOT installed the required update.
