VEX motor w/o robot controller?
Can a VEX motor (PWM-3wire) be modified to work directly connected to a battery so that we do not have to use the robot controller and radio to turn the motor on/off?
Re: VEX motor w/o robot controller?
Yes it can.
Just don't use it to compete in any FIRST or VEX events. |
We don't plan on using the VEX motor in competition. We are using VEX materials to prototype. We don't have any Tetrix stuff yet.
I've thought very vaguely about how minibots can be designed - simply put, our team is holding off on that for now in order to ensure the Robot has a solid design and will be finished on time.
However, reading this made me go look at the rules, and they raise an interesting question.. There's nothing in the MINIBOT section specifically that would prevent this. However, it would appear that <R48> applies: Quote:
So.. are you asking how to do it, then?
Yes..how?
Maybe I should have been more clear. We are using VEX motors for prototyping MINIbots designs. We will NOT use them in competition we are only testing ideas. We have tried stripping the wires from the VEX motor (PWM connection) and tried directly connecting them to the battery. BUT the motor does not spin. We have tried ever combination of wire colors possible. Last edited by grosh : 13-01-2011 at 16:29. |
#7
Also, your "hey let's just try hooking up these wires" approach to problem solving frightens me. I don't know what battery you're using, but please be aware of the safety considerations involved in doing such a thing. Your approach could lead to a deadly situation given different circumstances, say, 120VAC instead of low voltage DC. Have the patience to learn what you are doing from someone who already has. Last edited by sanddrag : 13-01-2011 at 17:24. |
#8
Eagle,
The robot rules have been slightly modified by Team Update #1 and only the two sections at the end of the manual apply to the minibot. R48 does not apply to the minibot for instance. Grosh, I hope you haven't killed the VEX motor. You are lucky you haven't burned yourself or damaged the battery. Do some research first, then make an informed decision on how to hook something up. |
#9
Granted, I think the intent for the game is clear, made even more so by the demonstrations at kickoff... but the wording of the rules still doesn't seem to make that distinction clear. |
#11
Eagle,
I will check and get back to you. Grosh, The 9.6 volt battery is 1000maHr and 7.2 volt battery is 3000 maHr. Either can produce fire if misused and under certain conditions can produce burns, and explosive release of gases generated within the battery. Either of these batteries when fully charged is capable of several tens of amps into a short. A standard nine volt battery is about 500 maHr but can't source nearly the current that NiCd or NiMH technologies can. |
#12
Do you have the new 2 wire motor 269s or 393s? They are both already wired for 2 wire use and come with their mini gear boxes. - The 2 wire motors were designed so future VEX teams could possibly make their own custom circuits.
