Go to Post ...when the rack starts swaying you start praying! - Wayne C. [more]
Unread 13-01-2011, 15:52
Rabbii Rabbii is offline
FRC #3308 (JHS Beavers)
Rabbii is an unknown quantity at this point
Arm
This year for logomation we are trying to make a hand. but we are all new and have little experience with robotics arm
We are thinking about a V shaped pincer type hand which goes up and down by a elevator.
What you guys think about that, and please give us suggestion for different type of arms and what does our idea sounds like to you.
We really need alot of help
Unread 13-01-2011, 16:03
winglerw28 winglerw28 is offline
FRC #1274
winglerw28 is an unknown quantity at this point
Re: Arm
I think the best starting point is a simple arm with 3 parts to turn and change elevation. The hand/clasp for the tubes should be slightly rounded, like pincers, to begin with. From there simply see what works with experimentation.
Hope I helped,
Will
Unread 13-01-2011, 16:05
Pirkey's Avatar
Pirkey Pirkey is offline
FRC #1732 (Hilltoppers)
Pirkey will become famous soon enough
Re: Arm
I would suggest going on www.thebluealliance.net and watch the game from 2007 for ideas.... it's basically the same and there are some good robots.
Unread 13-01-2011, 16:10
arkangle's Avatar
arkangle arkangle is offline
FRC #0639 (code red robotics)
Team Role: CAD
arkangle is an unknown quantity at this point
Re: Arm
i would use something like an human arm...
Unread 13-01-2011, 16:12
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Arm
Scissor lifts, like what you're talking about, can work, but in my experience they are heavier than arms, and slower. They do collapse into a very small volume when designed properly, so it would be beneficial to having a low CG.
Unread 13-01-2011, 16:19
FRC #1274
Re: Arm
Here, try looking at this:
Unread 13-01-2011, 17:33
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Arm
This is what gave me inspiration:
http://www.gearingupproject.org/watc...t-2-countdown/
@ 9:30 to 10:50
