Go to Post To paraphrase a common answer from the GDC: There is no rule that explicitly forbids this. - MechEng83 [more]
Unread 13-01-2011, 16:20
Biolore Biolore is offline
Lead Programmer
AKA: Josh
FRC #3597 (Robo-Rangers)
Biolore is infamous around these partsBiolore is infamous around these parts
Classmate Netbook
Can you use the classmate Driver station to control things on the robot, or does everything have to be from a controller and autonomous?
Unread 13-01-2011, 16:29
Re: Classmate Netbook
I don't think you phrased that in a way that will get you a useful answer.
The answer to the question I see there is this: Yes, you can use the Driver Station to control the robot. In fact, you must use the Driver Station software in order for the robot to function. You don't have to run it on a Classmate, as any recent Windows computer with an Ethernet connection should be able to support it, but you do need it. You can make everything autonomous if you want to, but you probably shouldn't.
(The answer to a question I think you might be asking instead is this: The MINIBOT doesn't have to have something called a controller, but it must be completely autonomous once it has separated from the HOSTBOT.)
Unread 13-01-2011, 21:29
Lead Programmer
AKA: Josh
I want to make preset heights for an arm (I'm my team's programmer), but I don't want to make the arm only be able to go to the preset heights. I just want to know if I can put buttons on the driver station on the Classmate (or whatever laptop is used) in order to tell the arm to go to some predetermined height, within what is allowed in the teleop portion of the game.
Unread 13-01-2011, 21:36
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Teams are allowed to create custom control boards using the Cypress I/O board. You can wire up physical controls (dials, arcade buttons or joysticks) to the board and read their values from the robot.
Unread 14-01-2011, 12:27
Lead Programmer
AKA: Josh
Ok, but can you put virtual buttons on the dashboard to be used during the game?
Unread 14-01-2011, 12:30
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
From personal experience from last year, NOT in the DRIVER STATION section (the lower half). The Dashboard (the upper half), however, can be changed through the use of LabView, and I would assume it's possible.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 14-01-2011, 12:55
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
As far as I know, you can not send data back from the Dashboard to the robot, so if you wanted to use something other than a joystick to set the height, you would have to use the cypress I/O board.
Unread 14-01-2011, 15:04
Owen Meaker Owen Meaker is offline
FRC #4180
Owen Meaker is an unknown quantity at this point
You cannot put virtual buttons on the dashboard, but there are already some there on the input tab. You can use these if you wish. I used them last year to set driver settings (eg. inversing the controls for the people who like it that way).
