Go to Post There are always rules we don't agree with, just like in life. Our character is defined by how we respond. - Mr MOE [more]
Unread 12-01-2011, 19:29
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: 4W Maximum Power Servos? Huh?
Originally Posted by EricVanWyk View Post
Man, this is harder than I thought - these servo vendors sure don't like to make things easy for us. What the heck is an ounce inch? seconds per 60 degrees? Seriously? I miss newton meters and radians per second
I too wish that torque ratings were standardized. I've been on websites that have a different unit for every product they sell. However, newton meters are HUGE units. Servos, in general, are really weak. Milli Newton Meters are used more more often in this case (or kg-cm, or oz-in, or g-cm, or...)
Unread 12-01-2011, 20:17
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
I sure hope they aren't using kg-cm or g-cm for torque measurements. (Kilo)grams are a unit of mass, not force.
Art Dutra IV
世上无难事,只怕有心人.
Unread 12-01-2011, 21:18
Check out the kg-cm on this sheet:
http://www.servocity.com/html/hs-325hb_bb_deluxe.html
I wonder if their performance depends on local gravity...
Unread 13-01-2011, 13:29
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
Wouldn't the electrical power draw (max) be stall current times the operating voltage? And by stall, I mean not just current drawn when holding position but just barely holding position against the maximum torque load.
- Steve
Unread 13-01-2011, 14:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I blame the imperial system and its conflation of mass and force units. Someone's clearly trying to foist that horrible convention on the metric system under the guise of it being "easier". It might be in retaliation for the slug... but that clearly WAS a good idea that would've made things easier.
Unread 13-01-2011, 16:55
AKA: Alan Wells
FRC #1350 (Rambots)
I know, it's terrible , but it is used.
http://www.onlineconversion.com/torque.htm
Unread 13-01-2011, 18:16
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Maybe it turns the other way when you flip it over.
-- Marshal Horn
Unread 16-01-2011, 20:33
hilo90mhz hilo90mhz is offline
FRC #2024
hilo90mhz is an unknown quantity at this point
Does this mean we can use VEX servos/drive motors in the main robot?
Would be helpful for our claw actuator.
Unread 16-01-2011, 20:36
EricH EricH is online now
Servos, yes, provided that they are under 4W. VEX motors, not so much, due to <R46> disallowing anything not allowed under <R45> and <R45> not specifically allowing VEX motors.
Unread 16-01-2011, 21:11
FRC #2024
I guess the real question then is do these two count as the same thing? the three wire motor is essentially a continuous rotation "servo" called a motor in this instance by vex.. it all depends on definition now.
3 Wire Motor
http://www.vexrobotics.com/products/.../276-2163.html
3 Wire Servo
http://www.vexrobotics.com/products/.../276-2162.html
Here is one that is labeled "correctly" depending on your viewpoint...
Continuous rotation servo
http://www3.towerhobbies.com/cgi-bin...&I=LXSYK3&P=FR
I also posted a similar question on the usfirst forum, we will see what they have to say also..
http://forums.usfirst.org/showthread.php?t=16325
Our team would like to use a few "continuous rotation servos" to spin some wheels in our claw mechanism this year.. Trying to figure out if this is legal..
Unread 16-01-2011, 21:21
Quick tip on your thread location: Try posting it in the Q&A instead of the general area. You'll need to have your team's main contact do it, though--they're the ones with the passwords to ask questions.
A servo and a motor are not the same thing. A servo goes to a position it's commanded to go to and stays there. A motor spins when powered. You can make a motor into a servo by adding sensory feedback onto whatever it's actuating. It's a whole lot harder to make a servo into just a motor. It's that commanded motion that makes a servo a servo.
Servo motors are a type of motor that can be directed to turn to face a specific direction, rather than just spin forward or backward.
(From the VEX servo page linked to earlier, emphasis mine.)
Servo != motor. Motor != servo.
Unread 16-01-2011, 22:13
FRC #2024
I agree a servo != a motor.
I guess what matters is what the rule makers want the rule to mean..
It seems to me that most of the rules limit what motors are allowed, in this case the same internal motor would be used just with a different output mechanism.
The motor controller is still built into it like a servo.
I have modified servos to turn continuously in the past, depending on the internal gearing this is fairly easy, or impossible if the teeth on the main output gear are not complete.
Unread 18-02-2011, 15:51
mcbean mcbean is offline
FRC #2377 (ccompany)
mcbean is an unknown quantity at this point
you guys prob already saw this since this thread is old, but if you haven't team update 3 addresses this issue
http://usfirst.org/uploadedFiles/Rob..._Update_03.pdf
Unread 23-11-2011, 13:45
LinuxArchitect LinuxArchitect is offline
AKA: George Boyce
FRC #0053 (Cow Abductors)
LinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to allLinuxArchitect is a name known to all
For those like me looking to understand team update # 3 from last year, the update reads
calculate servo max power as stall torque x no load speed
and then they give an example for the HS-322 which, at 6v, has a stall torque of 3.7 kg/cm and a speed of 0.15 sec for 60 degrees, and they give the final formula as
torque = 3.7 kg/cm = 0.36 Nm
RPM = 0.15s @ 60 degrees = 66.7 RPM
and the result is
0.36 * 66.6 * 0.1046 = 2.5W, and thus under the 4.0W limit.
But where did some of those numbers come from I/you ask?
Well 1 Kg/cm = 0.0980665 Nm which you know from looking it up, say at http://www.onlineconversion.com/torque.htm, or from basic physics. A newton is the measure of force necessary to move a mass of one kilogram a distance of one meter in one second. The force of gravity on 1 kg is about 9.8 newtons, depending on your location, etc.
So that is how 3.7 Kg/cm * 9.8N/kg * 1m/100cm = 0.36 Nm
RPM is just algebra, no physics... 60 degrees is 1/6th of a circle so 0.15sec to travel 60 degrees becomes 0.15*6=0.9 sec for 1 revolution.
1rev/0.9sec * 60 sec/min = 66.7 rpm
So far we have N-m * Rev/min and we want an answer in watts. Ah, a watt is by definition one N-m/sec.
The last item is 0.1046 which, again, we know from a conversion table like at http://www.micromo.com/motor-calculations.aspx, but what it represents is the conversion of RPM to radians/second.
I hope this explains how stall torque x no load speed, or 3.7 kg/cm * 0.15s @ 60 degrees, became the equation 0.36 * 66.6 * 0.1046
Let me know if I messed any math or physics. Ignore me if I caused more confusion than I resolved.
Unread 23-11-2011, 14:35
Just for the record:
The peak power for a DC motor is not equal to stall torque times no load speed.
Assuming the torque vs speed curve is linear, it is equal to 1/4 of that:
The peak power occurs at the middle of the torque vs speed curve, where torque is half the stall torque and speed is half the no load speed.
