Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 13-01-2011, 16:42
Turbinator Turbinator is offline
In Charge of Brain"ing" the Bot
AKA: Amninder Singh
FRC #3053 (NASA/MVB Stingers)
Turbinator has a little shameless behaviour in the past
Pneumatic Actuator
Hola, We are thinking of using the pneumatic actuator to help rotate our pickup arm. Anyone have any experience with these? Any diagrams or advice is always helpful.
Unread 13-01-2011, 17:07
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Re: Pneumatic Actuator
The little rotary actuator that you can get from Bimba can barley pick up itself.
It's useful to turn small things that don't require a lot of torque. I think the only time we successfully used it for anything was to trigger the balls into out shooter for Aim High.
Unread 13-01-2011, 17:26
dudeman2009 dudeman2009 is offline
Electrical/pneumatics
AKA: Jon
FRC #1504 (The Desperate Penguins)
Team Role: Electrical
dudeman2009 is an unknown quantity at this point
If your wondering pneumatics are good for fast movement. just make sure you get the right ones because some are very wimpy and cant lift them selfs.
for more information on grippers/pros and cons goto:
http://d1pytrrjwm20z9.cloudfront.net...atorDesign.pdf
there is some useful information there.
Hope I helped let me know if you have questions.
Unread 13-01-2011, 17:51
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Also, although is seems one wasn't provided for this year, it might help to check out the pneumatics manual from last year; http://www.usfirst.org/roboticsprogr....aspx?id=18068
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 14-01-2011, 15:35
Bob Steele's Avatar
AKA: Bob Steele
We actually used the rotary actuator in 2007 to turn our game piece from vertical to horizontal
It was tough though... and we had to play with the Moment of Inertia on our claw to make it work
It was painful to watch actually...it just BARELY turned it...usually.
I, too, wouldn't recommend that you count on the rotary actuator for much work....
Unread 15-01-2011, 00:53
DonRotolo's Avatar
Back to humble
FRC #0832
Pneumatics are excellent for motions that require two positions (one end and the other end), where the transition between the two positions must be fast, and where the forces required are not very large.
Understand how a rotary pneumatic actuator works. Basically, it is one (or two) small cylinders pushing an arm that rotates. Those small cylinders do not generate much force. So, for turning a small lever arm, they might be great, but for a large arm (like I might imagine for this year's game) you might be disappointed in the power. Check the specs to be sure.
