Go to Post Isn't FIRST robotics the answer to life, the universe, and everything? - weberr [more]
Unread 13-01-2011, 18:34
Keith Cancel Keith Cancel is offline
FRC #2130
Keith Cancel is an unknown quantity at this point
Wind River's VxWorks Throwing Error (~Assistance Please~)
Hello, I have installed wind River, updated the cRIO and the classmate, but I am having one issue with wind River when I try to connect via VxWorks I get these following errors below. I am able to deploy code via the FIRST downloader, but I can not connect via VxWorks and use the debugger ect. Thus, any help would be greatly appreciated as I am stumped/perplexed. I have also tried reinstalling Wind River to no avail, and if any one else needs any more information please feel free to ask. Thank you Keith Cancel.
Thu Jan 13 15:25:15 2011
    Target name is 10.21.30.2
tgtsvr (VxWorks6x_10.21.30.2@User-PC): Thu Jan 13 15:25:15 2011
    WTX Library version: 4.1.1.22
    Tgtsvr core version: 4.1.1.17
    Wind River Target Server: Win32 version
    Connecting to the target agent ...
    ... switching to WDB4 mode ...    ... succeeded !
    Loading plug-in for VxWorks... succeeded.
    Checking License... OK
    VxWorks plugin version: 4.1.1.11
    Attaching elf OMF reader for PPC CPU family... succeeded.
    Error: loading core symbol table: status = 0xe0004
    Error: Unable to load /c/ni-rt/system/vxWorks
    Error: Unable to load the kernel image into the target server.
Error during target server core initialization
Target Server will exit
~~~~~Solved~~~~~
I solved it. I simply forgot to select the kernel image when I created my VxWorks Connection. So the location of the kernel was located at C:\WindRiver\WPILib\vxWorks. You can look at lasts years documentation pages 6 and 7 http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
Unread 13-01-2011, 19:59
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Wind River's VxWorks Throwing Error (~Assistance Please~)
Target Server will exit[/code]
Is that the full and correct path of the vxWorks kernel image on your host?
Are you using Linux?
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 13-01-2011, 20:03
FRC #2130
No, I am not using Linux, Wind River is running on vista.
Unread 13-01-2011, 20:15
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Then you have apparently entered the wrong path for the vxWorks kernel.
Use the browse button to navigate to the kernel file -- on your host computer.
Unread 13-01-2011, 21:06
FRC #2130
I solved it I forgot to select the kernel image when I created my VxWorks Connection. So the location of the kernel was located at C:\WindRiver\WPILib\vxWorks. You can look at lasts years documentation pages 6 and 7 http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
Unread 14-01-2011, 02:29
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The kernel gets installed with the update to C:\WindRiver\WPILib\vxWorks
Unread 14-01-2011, 11:09
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
Solved
~~~~~Solved~~~~~
