Go to Post This isn't about practical, it's about having fun and thinking outside the box... tetrahedron.... whatever....:rolleyes: - Cyberguy34000 [more]
Unread 13-01-2011, 18:28
Da Kid's Avatar
Da Kid Da Kid is offline
FRC #2957
Da Kid is an unknown quantity at this point
What wheels for 6WD
our team has decided to use a dropped center 6WD for our drive. i am wondering what are the best type of wheels to use for it?
Unread 13-01-2011, 18:30
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
Re: What wheels for 6WD
Rough top or Wedge top 4in plaction wheels. That what our team is working on now.
Unread 13-01-2011, 19:04
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
If there was a best, every team would be using them. There are compromises to all of the wheels. And size (diameter) depends on your transmissions and strategy. Are you using the Kit transmissions? Does your strategy favor speed or power? You probably want to use CIMS on the transmissions, can you use 1 or 2 per transmission?
Unread 13-01-2011, 19:12
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Crusaders)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Our team is using 4 Plaction + 2 Omni 4 inch wheels. This made our drive simpler by allowing us to do a 6WD without dropping the center wheel. We chose 4 inch wheels because it lengthens our wheel base by 2 inches from the 6 inch wheel and 4 inches from the 8 inch wheels. With the transmission we chose, the 4 inch wheels gave us a reasonable high speed ~15.5fps (no load).
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST Hawaii Regional
-FIRST San Francisco Regional
Unread 13-01-2011, 20:41
Da Kid's Avatar
FRC #2957
we will probably be using the toughboxes or maybe the CIMple box but we didn't get that yet since they were short the chassis box at kickoff. we would probably want speed. and we will use one CIM motor for each side since there is the limit of four and we would like to use some on our arm.
