Go to Post "Field orientation is like a homing pidgeon that can fly backwards." - LostWolf [more]
Unread 13-01-2011, 19:26
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Best way to control the mechanum wheels
Show me the rule, because I can't find that one in the Game Manual Section 4.
In 2008, I know I found a link to some "canned" mecanum code lying around CD. However, the programming language that year was C, so it wouldn't work this year without modification. I might be able to find it again... but it would take a while.
Originally Posted by Alan Anderson View Post
I'm not aware of that restriction. Where did you find it?
I thought wrong then. So ,in the off season, technically I can spend my time writing my own library that would directly communicate with the FPGA or even modifying the FPGA to run my own library?
