#31
Re: Mini-bot Ideas
When I saw the little guy on the game animation, I instiantly figured we could use Hexbug parts. I was thinking of how cool it would to have a modified Ant Hexbug race up the tower.
#32
Re: Mini-bot Ideas
I personally think as of now with the current rules, launching a minibot up the tower, while it starts at the base is legal. I do not think firing the minibot across the field is however as I look at the definition of deployment and safety. Also to whoever said the tennis ball idea I'm 99% sure that wasn't in the list of parts for the minibot.
#33
Re: Mini-bot Ideas
parts list
#34
Re: Mini-bot Ideas
just keep in mind everyone... It's not going to take very much force at all to trigger the thing at the top so all the minibot has to do is reach the top before another does... Given that the bot has only 10 seconds to reach the top, at that velocity it will most definitely trigger.
#35
Re: Mini-bot Ideas
<G19> was reinstated that a host bat can't launch the mini bot up the pole, or contribute to the vertical movement, and energy for vertical deployment cannot be stored in the minibot before deployment.
It also states that the minibot has to be deployed on a tower or else a penalty of the highest race score is implied. I think that now throwing the minibot from the hostbot should be out of the design, it seems as if they want us to build the minibot like a FTC team would. <R92> A. has TETRIX components that are not in violation of any other rules. |
#36
Re: Mini-bot Ideas
Thank you,
<G19> MINIBOTS must remain completely autonomous and move up the POST solely through electric energy provided after DEPLOYMENT by the permitted, unaltered battery and converted to mechanical energy by the permitted unaltered motors (and associated, appropriate circuitry). Violation: The TOWER on which the MINIBOT is DEPLOYED is disabled. If the MINIBOT is DEPLOYED on something other than a TOWER, then the ALLIANCE’S TOWER upon which the highest RACE SCORE was earned will be discounted. <G19> means that HOSTBOTS are not allowed to launch the MINIBOT up the pole at the TARGET, or otherwise contribute to the vertical movement of the MINIBOT. Energy for vertical movement may not be stored in the MINIBOT before DEPLOYMENT (except that which is contained within the battery and excluding incidental kinetic energy stored in the motors or wheels, but NOT, for example, in a flywheel). |
#37
Re: Mini-bot Ideas
Now that we've received some design changing news, does anybody have non-stored-energy-that-contributes-to-the-vertical-movement-of-the-robot ideas?
#38
Re: Mini-bot Ideas
I don't know that there would be anything more efficient than wheels, to be honest. (Given the design restraints.)
I don't mind the FTC thing... I just wish that we had to use the battery/no-stored-energy restriction and **weren't allowed** to use wheels... ![]() |
#39
Re: Mini-bot Ideas
One of my friends mentioned corkscrews. I dont know how it would work, but it would be interesting.
#40
Re: Mini-bot Ideas
I'm sure that the robot has to move under its own power after the first 18 inches of the pole. (also sure you can't use springs)/.
#41
Re: Mini-bot Ideas
didn't read everyones but the robot has to be self driven-that means no springs or rocket boosters
the general sensus seems to be that putting the robot on the pole is quicker than having it drive off the 'hostbot' so likewise it would be good for teams to have a deployment system that does not require the mini to drive. |
#42
Re: Mini-bot Ideas
Hmm. How about utilizing magnets, like a maglev train?
Use the magnets to attach to the steel pipe, then flip a switch and propel it to the top? Would it work? |
#43
Re: Mini-bot Ideas
Team Update #1 clarifies <G19> to make spring-launching a MINIBOT illegal. The HOSTBOT can't give any upward motion to the MINIBOT. The MINIBOT must climb using only a motor powered by its battery, with no other stored energy permitted.
#44
Re: Mini-bot Ideas
This might sound like a dumb question, but is an electromagnetic still considered an acceptable mini-bot part (AA. magnets)? |
#45
Re: Mini-bot Ideas
