Go to Post "Defense wins qualifying rounds, offense wins championships." - Paul Copioli [more]
Unread 13-01-2011, 00:28
Laura Rhodes Laura Rhodes is offline
FRC #0100
Laura Rhodes is an unknown quantity at this point
DAP-1522 - Errors Setting IP Address
We're having trouble configuring the Static IP address setting on our new DAP-1522 radio. We followed the instructions in the manual "How to Configure Your Radio.pdf", and tried to enter an access point IP address of 10.1.0.1 (to comply with the form 10.xx.xx.1 for team # 100).
An error message pops up that states that 10.01.00.1 is an INVALID IP address.
We tried entering the IP address in a variety of forms thinking it may be a parsing error (10.1.0.1, 10.01.0.01, 10.01.00.01, etc.). All resulted in the same error message.
The radio WILL accept 10.19.95.1 (as in the example) and 10.10.0.1 (tried in desperation) but will not accept the proper IP address required for Team 100.
What else should we try?
_________________
FRC Team 100, Mentor
Woodside Robotics
Unread 13-01-2011, 20:02
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Re: DAP-1522 - Errors Setting IP Address
We had the same problem with 10.21.06.1
We finally fixed the problem by using 10.21.6.1
I don't know how this works if you have a team 216, but it's what we will use for now. As for team 100, I don't know. It seems to dislike leading zeros though. Perhaps something that should be brought up with FIRST?
"Don't worry, programming can fix it"
Unread 14-01-2011, 09:53
ATannahill ATannahill is offline
AKA: Alex Tannahill
Team 216 will use the ip 10.2.16.1.
- Arizona North
Unread 14-01-2011, 09:55
AKA: Bobby
I'm well aware of this, but it is what we are using for now until we can figure out how to get it to accept 10.21.06.1
Unread 14-01-2011, 10:01
AKA: Alex Tannahill
These posts are contradictory. 10.21.6.1 is not the same as 10.2.16.1. There will be no problem.
- Arizona North
Unread 14-01-2011, 10:32
AKA: Bobby
Oh your right, my bad, I had misread what myself and the others wrote. XD My mistake
Unread 14-01-2011, 13:01
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
For the OP have you tried 10.1..1? Seeing as it doesn't like 0's it might accept nothing there.
Unread 14-01-2011, 14:02
I tested your IP address with our radio and didn't get the error message, not that it helps you fix your issue.
I did confirm that it doesn't like, and won't accept, leading zero's.
e.g.,
Good: 10.3.58.1
Bad: 10.03.58.1
