Go to Post ...okay, maybe I have a xkcd addiction - plnyyanks [more]
Unread 13-01-2011, 20:36
ProgrammerMike7 ProgrammerMike7 is offline
AKA: Mike
FRC #2200 (MMRambotics)
ProgrammerMike7 will become famous soon enoughProgrammerMike7 will become famous soon enough
ADXL345_I2C Help
Hello everyone! I have been trying to get the ADXL345 accelerometer working. I have it connected to the I2C spare outputs. Here is my code:
#include "WPILib.h"
class MyRobot : public IterativeRobot {
	ADXL345_I2C myAccel;
	DriverStationLCD *driverStation;
public:
	MyRobot():
		myAccel(4, ADXL345_I2C::kRange_2G)
		driverStation = DriverStationLCD::GetInstance();
	void TeleopInit() {
		GetWatchdog().SetEnabled(true);
		driverStation->Clear();
	void TeleopPeriodic() {
		GetWatchdog().Feed();
		char xAccelChar[100];
		char yAccelChar[100];
		sprintf(xAccelChar, "Accel X: %f", myAccel.GetAcceleration(ADXL345_I2C::kAxis_X));
		sprintf(yAccelChar, "Accel Y: %f", myAccel.GetAcceleration(ADXL345_I2C::kAxis_Y));
		driverStation->PrintfLine(DriverStationLCD::kUser_Line1, xAccelChar);
		driverStation->PrintfLine(DriverStationLCD::kUser_Line2, yAccelChar);
		driverStation->UpdateLCD();
START_ROBOT_CLASS(MyRobot);
When I run this program, the display on the driver station reads:
Accel X: 0.00000
Accel Y: 0.00000
No matter how much the accelerometer is moved around, these values do not change. Does anyone have any ideas as to what I can do to make the accelerometer work?
Wait (-1)
Unread 14-01-2011, 02:35
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: ADXL345_I2C Help
Are you getting any errors on the diagnostics tab of the driver station or on the Console?
Are you sure of your wiring? Make sure clk and data are not swapped.
Unread 14-01-2011, 17:52
basicxman basicxman is offline
Emily Horsman
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Nothing; although the I2C class has many assertions, none seem to be failing (or at least communicating a failure). The ADXL345_I2C class has no assertions besides the ones from I2C calls.
Quite positive, the board and the I2C spare outputs on the digital sidecar are labelled. An accelerometer example VI also depicts a wiring diagram.
Unread 15-01-2011, 11:35
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
I would start by putting a scope on the I2C pins to see if they're being diddled.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 16-01-2011, 15:33
While they are labeled, I want to verify that you are connected to the 4 pins closest to the NXT RJ connector. The 4 pins farther from it are low-speed digital output lines (that are not supported by WPILib).
-Joe
Unread 16-01-2011, 17:00
AKA: Mike
They are.
Wait (-1)
Unread 16-01-2011, 18:43
Emily Horsman
-Joe
They are.
I believe Michael is correct, we have also tried different digital sidecars, including the one from our 2011 kit. Tomorrow we will post our full source code (updated), software versions, and a picture of our wiring setup.
Unread 16-01-2011, 21:05
#include "WPILib.h"
public:
	MyRobot():
	void TeleopInit() {
Accel X: 0.00000
Accel Y: 0.00000
I'm not quite sure what to tell you. I tried both the program above and a program I had laying around, and both worked just fine. It makes me tend to think that you either really do have a wiring/hardware issue or perhaps you have some software that is not updated.
Here's the other application I tried which also works on my system:
#include "WPILib.h"
class TestADXL345_I2C : public SimpleRobot
	ADXL345_I2C acc;
public:
	TestADXL345_I2C(void)
		: acc (4, ADXL345_I2C::kRange_2G)
	void RobotMain(void)
		while (true)
			printf("x=%f  y=%f  z=%f\n",
				acc.GetAcceleration(ADXL345_I2C::kAxis_X),
				acc.GetAcceleration(ADXL345_I2C::kAxis_Y),
				acc.GetAcceleration(ADXL345_I2C::kAxis_Z));
			Wait(1.0);
START_ROBOT_CLASS(TestADXL345_I2C);
Unread 17-01-2011, 15:56
Emily Horsman
http://www.chiefdelphi.com/forums/at...d=129529771 6
Apologies for the poor quality of the image.
WindRiver Version: 3.0.1
WPILib Version: rev2242
Name:	2011-01-17 15.47.58.jpg
Unread 20-01-2011, 00:01
Dutch8az Dutch8az is offline
FRC #2827
Dutch8az is an unknown quantity at this point
Power
I am definitely a beginner programmer but I thought that a file I read said that the accelerometer would start in power saving mode unless you wrote 0x08 to POWER_CTL (0x2D) and it would be unresponsive unless this was implemented
here's the file link:
http://usfirst.org/uploadedFiles/Rob...sor_Manual.pdf
sorry if im just imputting random info again I am really new to the coding world
Unread 20-01-2011, 13:19
Emily Horsman
Re: Power
Great attention to detail, however the WPI Library already does this.
Unread 20-01-2011, 13:27
Have you tried looking at the lines with a logic analyzer or a scope yet?
Unread 20-01-2011, 13:28
Emily Horsman
Not yet, I haven't had a chance to bring in my USB logic analyzer yet.
Unread 26-01-2011, 18:12
AKA: Mike
We had last years ADXL345, so we wired that up and it works fine. However, we encounter another problem when having the HiTechnic Compass plugged into the NXT I2C port at the same time the accelerometer is plugged into the spare I2C port. They both work and display values when they are plugged in alone, however when they are both plugged in together, neither will update values and display 0.000000. We do not get any errors, they simply do not work. We also checked the compass and accelerometer source code to make sure that the compass and accelerometer had different addresses which they do (Accelerometer is 0x3A, and compass is 0x02). Here is the code with the Compass added.
#include "WPILib.h"
	HiTechnicCompass myCompass;
	double xAccel, yAccel;
        double compassAngle;
public:
	MyRobot():
		myCompass(4),
	void TeleopInit() {
		GetWatchdog().SetExpiration(0.5);
		while(IsOperatorControl() && IsEnabled()) {
			char compassChar[100];
			char testChar[100];
			xAccel =  myAccel.GetAcceleration(ADXL345_I2C::kAxis_X);
			yAccel =  myAccel.GetAcceleration(ADXL345_I2C::kAxis_Y);
			compassAngle = myCompass.GetAngle();
			sprintf(xAccelChar, "Accel X: %f", xAccel);
			sprintf(yAccelChar, "Accel Y: %f", yAccel);
			sprintf(compassChar, "Compass: %f", compassAngle);
			driverStation->PrintfLine(DriverStationLCD::kUser_Line3, compassChar);
We would appreciate any advice that could fix this issue.
Wait (-1)
Unread 18-02-2012, 15:53
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Did you ever resolve this issue?
TIA,
Mike
