Go to Post I'm pretty sure most teams would be OK with being somewhere between Division by Zero and Cheesy Poofs! ;) - Dennis Jenks [more]
Unread 13-01-2011, 22:06
fhsroboticsteam fhsroboticsteam is offline
FRC #3414
fhsroboticsteam is an unknown quantity at this point
Question Mecanum Direct drive
We are considering building a direct drive config similar to this one by andymark
http://www.andymark.com/ProductDetai...ctCode=am-0485
These would be using the tough boxes from last year and 6" mecanum wheels.
and for the gear boxes we would need to buy theses
http://www.andymark.com/productdetai...ctcode=am-0211
I was wondering if this configuration could support the weight of the robot. It would be putting a lot of strain on the tough boxes.
And would the gear ratio be too high? 12.75:1 with 6" mecanum wheels?
what could happen if our robot is geared too high?
Unread 13-01-2011, 22:20
dtengineering's Avatar
AKA: Jason Brett
Re: Mecanum Direct drive
The axles will need to be supported in two places. You could say that the axle IS supported in two places already... the inner and outer bearings in the toughbox, but they are pretty close together. If you keep the wheel really, really close to the toughbox, though... you'll probably be okay.
It is an issue of torque... when using just the toughbox bearings, the axle is a lever and the bearing nearest the wheel is the fulcrum. As the wheel gets further away from the fulcrum, it starts to develop mechanical advantage and pushes "up" on the bearing near the wheel, and "down" on the bearing away from the wheel.
The toughboxes are pretty tough, but I'd still consider putting some outboard bearing support in there. You'll probably be fine with the wheels set up as you plan, but I can guarantee you'll be fine with the wheels set up like this: http://www.youtube.com/dtengineering#p/u/0/xgTJcm9EVnE
Jason
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Your links aren't working for whatever reason, so I'll just tell you what I know about mecanums. 16:1 on 8" mecanums is very well balanced setup.
As for mounting the wheels directly on the toughboxes, I'd strongly recommend against it. A better bet would be to mount the wheels on the chassis, and have them chain driven to the toughboxes which are situated on top of the chassis.
Another alternative to toughboxes is Banebots transmissions, they're what we always use.
Go REX!!!
Unread 13-01-2011, 22:34
Chris is me's Avatar
AKA: Pinecone
Mounting wheels directly to a Toughbox Nano should be fine if you keep them close to the box.
Unread 13-01-2011, 23:22
FRC #3414
So you think that 12:1 would be to low of a ratio (causing the wheels to spin too fast) on 6" wheels?
Unread 13-01-2011, 23:26
FRC #3414
Jason
What gear box/gear ratio were you using in the video you linked me to?
Unread 13-01-2011, 23:34
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
A standard AM Toughbox at 12.75:1 with a 6" mecanum wheel should give you around 7-8 ft/s.*
*With 8" wheels on the same gearbox, we were measuring 10ft/s consistently. Hopefully there isn't some funky issue with mecanums that would put my 6" wheel estimate off by any significant amount.
Unread 13-01-2011, 23:45
pfreivald's Avatar
AKA: Patrick Freivald
Direct drive systems absolutely must be supported on both sides of the wheel, and well. Pillow blocks (whether IGUS or from mcmaster.com) are very useful in this regard.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-01-2011, 00:04
AKA: Pinecone
Great drivetrain by 829 - cantilevered wheels
Unread 14-01-2011, 09:48
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
We direct drove our Mecanum drive last year on cantilevered TB-Nanos (hex shafts). We went over the bump once per match on average, and rarely had a 'soft landing' on the other side. Not only did we do 2 competitions (1 regular, 1 offseason), we also had about 15 hours of little kids driving the robot around at the USSEF. Everything was fine for the most part (dirt kept getting in the gearboxes from the SEF floor).
We had a very slight issue with our Toughbox Nanos that we discovered during the build season. One of the bearings on the output shaft could wiggle as if the gear wasn't spaced properly. We added custom-shaved washers to them, and they worked beautifully after that. I'll note that these were the first iterations of the TB-Nanos, and from what I can tell AM fixed that issue in the iteration after.
I'll also second Chris's statement about keeping the wheels as close to the gearbox as possible. Also use 2 hubs per wheel if you can since the wheel is slightly wider than the output shaft's length.
GitHub
Unread 14-01-2011, 10:29
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
I'd like to disagree. 810 has been direct driving mecanum wheels off of the BaneBots P80 transmission, unsupported for the past 4 years with absolutely no problems. Although the P80's do seem a little beefier than the ToughBoxes.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 14-01-2011, 10:40
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We used the Banebots P80 trannys in our testbed a few years ago. I think we used 16:1 or 12:1 with AM's 6" mechanums. I forget which. We did support our with the banebot barings.
http://www.youtube.com/watch?v=6VEHNhcsj6Q
Unread 14-01-2011, 10:51
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
We pounded that drive mercilessly over the humps through 4 competitions and many hours of practice without a single failure.
If you keep the load close to the gearbox you will not have any problems, especially on this years flat field.
Unread 14-01-2011, 19:52
pfreivald's Avatar
Well, what do I know, then?
Team 1551
I write books, too!
Unread 17-01-2011, 00:58
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Is that with the regular nano or the one with the long outputshaft
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
