Go to Post An extra week of driving practice and shakedown outweighs a lot of ooo-shiny. - Billfred [more]
Unread 13-01-2011, 22:55
paper: Simple Motor Calculator
Thread created automatically to discuss a document in CD-Media.
Simple Motor Calculator by Ether
Unread 13-01-2011, 22:56
Re: paper: Simple Motor Calculator
I created this small app for my own use, then realized that others might find it interesting/fun/handy.
Constructive criticism and error reports welcome.
Note: for those looking for something more comprehensive, check out JVN's calculator.
http://www.chiefdelphi.com/media/papers/2059
Unread 16-01-2011, 16:35
The updated version will allow you to enter a desired motor power, and it will then calculate the rpm range, the torque range, and the current range over which the motor will deliver at least that much power.
Also, if there is some reason why you want to always operate the motor at or above a certain efficiency, you can enter the desired efficiency and it will calculate the rpm range, the torque range, the current range over which the motor will operate at an efficiency equal to or greater than the entered number.
Unread 17-01-2011, 20:29
MrHance's Avatar
MrHance MrHance is offline
Long Distance Mentor
FRC #0647 (Cyber Wolf Corp)
MrHance has a spectacular aura aboutMrHance has a spectacular aura aboutMrHance has a spectacular aura about
Thumbs up Re: paper: Simple Motor Calculator
Ether, nice little program and simple to use. great work. As an Engineer, I am always impressed at what people come up with to solve simple problems when the use the theory of "STICK ON A STRING". If you keep this in mind when face with a problem, life will be great and a little less stressful.
Again, Do not stop what it is that you do best, GREAT WORK.
Unread 07-01-2012, 20:09
I have updated the motor calculator for the 9015 (am-0912) and PG71 (am-0914) 2012 motors.
The app is now 32-bit so it should now run in 64-bit Windows (XP & 7).
I am re-working the floating-point error trapping and will update again when that is done.
Enjoy.
Unread 08-01-2012, 00:53
Floating-point exception handling added.
MCALC32c.
Works in 32-bit or 64-bit Windows.
Scrollable window.
Includes 9015 (am-0912), PG71 (am-0914), and fc12-20 motors.
Unread 08-01-2012, 19:38
For anyone who has downloaded MCALC32, please be advised that the specs for the PG71 gearmotor are in dispute1.
As soon as this is settled, I will update the calculator.
Sorry for any inconvenience.
1 http://www.chiefdelphi.com/forums/sh...ad.php?t=99488
Unread 09-01-2012, 16:07
Motor Calculator build MCALC32g 1/9/2012 350p
Now supports the following motors:
CIM
FP0673
FP2719
FP9012
FP9015
RS395
RS540 (not legal for 2012 but included)
RS550
RS775-12
RS775-18
am-0912
am-0914
DensoL
DensoR
Denso AE235100-0160
Unread 10-01-2012, 13:16
Here's a copy-and-paste ticker tape output from the motor calculator. If you disagree with any of the specs please let me know. Thanks:
Motor Calculator  build MCALC32h 1/9/2012 643p
CIM FR801 001, AM802 001A @ 12.00 volts:
@ free (no load):
   oz-in      Nm     rpm    rpm%    amps   watts out    watts in    eff%
     0.0   0.000    5310   100.0     2.7         0.0        32.4     0.0
@ stall:
   343.4   2.425       0     0.0   133.0         0.0      1596.0     0.0
@ max power:
   171.7   1.212    2655    50.0    67.8       337.1       814.2    41.4
@ max efficiency:
    42.8   0.302    4648    87.5    18.9       147.1       227.3    64.7
FP 00801-0673 @ 12.00 volts:
@ free (no load):
     0.0   0.000   20770   100.0     0.8         0.0         9.8     0.0
@ stall:
    75.4   0.532       0     0.0   108.7         0.0      1304.4     0.0
@ max power:
    37.7   0.266   10385    50.0    54.8       289.5       657.1    44.1
@ max efficiency:
     6.0   0.043   19110    92.0     9.4        85.2       113.3    75.2
FP 000968-2719 @ 12.00 volts:
@ free (no load):
     0.0   0.000   16100   100.0     2.0         0.0        24.0     0.0
@ stall:
    57.5   0.406       0     0.0    63.0         0.0       756.0     0.0
@ max power:
    28.8   0.203    8050    50.0    32.5       171.1       390.0    43.9
@ max efficiency:
     8.7   0.061   13665    84.9    11.2        87.9       134.7    65.2
FP 000968-9012 @ 12.00 volts:
@ free (no load):
     0.0   0.000   15600   100.0     1.0         0.0        12.0     0.0
@ stall:
    59.5   0.420       0     0.0    63.5         0.0       762.0     0.0
@ max power:
    29.8   0.210    7800    50.0    32.3       171.6       387.0    44.3
@ max efficiency:
     6.6   0.047   13861    88.9     8.0        68.0        95.6    71.1
FP 000968-9015 @ 12.00 volts:
@ free (no load):
     0.0   0.000   15600   100.0     1.3         0.0        15.0     0.0
@ stall:
    63.7   0.450       0     0.0    70.0         0.0       840.0     0.0
@ max power:
    31.9   0.225    7800    50.0    35.6       183.7       427.5    43.0
@ max efficiency:
     7.5   0.053   13761    88.2     9.4        76.4       112.3    68.1
M3-RS395-12 @ 12.00 volts:
@ free (no load):
     0.0   0.000   15500   100.0     0.5         0.0         6.0     0.0
@ stall:
    16.7   0.118       0     0.0    15.0         0.0       180.0     0.0
@ max power:
     8.3   0.059    7750    50.0     7.8        47.8        93.0    51.3
@ max efficiency:
     2.6   0.018   13107    84.6     2.7        24.9        32.9    75.9
***NOTE*** RS540 is not legal for 2012
RS540 @ 12.00 volts:
@ free (no load):
     0.0   0.000   17200   100.0     0.9         0.0        11.2     0.0
@ stall:
    32.6   0.230       0     0.0    36.8         0.0       441.6     0.0
@ max power:
    16.3   0.115    8600    50.0    18.9       103.8       226.4    45.8
@ max efficiency:
     4.5   0.032   14841    86.3     5.8        49.1        70.2    70.0
RS550 stall torque changed to 70.5 oz-in per 2012 FRC specs
M5-RS550-12 (-B) @ 12.00 volts:
@ free (no load):
     0.0   0.000   19300   100.0     1.4         0.0        16.8     0.0
@ stall:
    70.5   0.498       0     0.0    85.0         0.0      1020.0     0.0
@ max power:
    35.3   0.249    9650    50.0    43.2       251.5       518.4    48.5
@ max efficiency:
     8.0   0.057   17105    88.6    10.9       101.4       130.9    77.5
M7-RS775-12 @ 12.00 volts:
@ free (no load):
     0.0   0.000    7300   100.0     1.1         0.0        13.2     0.0
@ stall:
    61.1   0.431       0     0.0    30.0         0.0       360.0     0.0
@ max power:
    30.6   0.216    3650    50.0    15.6        82.5       186.6    44.2
@ max efficiency:
     9.8   0.069    6127    83.9     5.7        44.5        68.9    64.5
M7-RS775-18 @ 12.00 volts:
@ free (no load):
     0.0   0.000   13000   100.0     1.8         0.0        21.6     0.0
@ stall:
   112.8   0.797       0     0.0    86.7         0.0      1040.4     0.0
@ max power:
    56.4   0.398    6500    50.0    44.3       271.2       531.0    51.1
@ max efficiency:
    14.2   0.100   11363    87.4    12.5       119.4       149.9    79.7
am-0912 (CCL 9015) @ 12.00 volts:
@ free (no load):
     0.0   0.000   16000   100.0     1.2         0.0        14.4     0.0
@ stall:
    60.6   0.428       0     0.0    63.8         0.0       765.6     0.0
@ max power:
    30.3   0.214    8000    50.0    32.5       179.4       390.0    46.0
@ max efficiency:
     7.3   0.052   14070    87.9     8.8        76.1       105.0    72.5
Specs for am-0914 (PG71) motor are disputed.
Update will be posted when available.
am-0914 (PG71) @ 12.00 volts:
@ free (no load):
     0.0   0.000      84   100.0     1.3         0.0        15.6     0.0
@ stall:
  4140.0  29.235       0     0.0    26.8         0.0       321.8     0.0
@ max power:
  2070.0  14.617      42    50.0    14.1        64.3       168.7    38.1
@ max efficiency:
   739.3   5.221      69    82.1     5.9        37.7        70.3    53.7
DensoL 262100-3040 @ 12.00 volts:
@ free (no load):
     0.0   0.000      84   100.0     1.8         0.0        21.6     0.0
@ stall:
  1501.1  10.600       0     0.0    21.0         0.0       252.0     0.0
@ max power:
   750.5   5.300      42    50.0    11.4        23.3       136.8    17.0
@ max efficiency:
   339.5   2.398      65    77.4     6.1        16.3        73.7    22.1
DensoR 262100-3030 @ 12.00 volts:
@ free (no load):
@ stall:
  1501.1  10.600       0     0.0    18.6         0.0       223.2     0.0
@ max power:
   750.5   5.300      42    50.0    10.2        23.3       122.4    19.0
@ max efficiency:
   357.4   2.524      64    76.2     5.8        16.9        69.6    24.3
Denso AE235100-0160 @ 12.00 volts:
@ free (no load):
     0.0   0.000    5300   100.0     1.0         0.0        12.0     0.0
@ stall:
    18.4   0.130       0     0.0     7.0         0.0        84.0     0.0
@ max power:
     9.2   0.065    2650    50.0     4.0        18.0        48.0    37.6
@ max efficiency:
     5.0   0.036    3846    72.6     2.6        14.4        31.8    45.2
Unread 12-01-2012, 23:00
I've just been informed (by someone in a position to know) that the "9013" in the KoP Checklist is an error: It should be 9012.
Team Update #2 (2012-01-13) added FP-9012 to [R48] and kept FP-9013.
The motor calculator supports the FP-9012. As soon as specs for FP-9013 become available I will add them to the calculator.
Unread 16-01-2012, 22:37
The motor calculator has been updated with the latest (1/16/2012) lab data for the am-0914 gearmotor.
I decided to incorporate 2 separate sets of motor specs for this gearmotor:
one for brand-new (unused) gearmotor, and
one for used (broken-in) gearmotor
... since the lab data indicated a significant difference.
** ACTUAL GEARMOTOR PERFORMANCE PROBABLY LIES SOMEWHERE BETWEEN **
Links to the 3 lab report PDF documents can be found at the bottom of this web page.
If you have even a passing interest in motor testing, you will find this interesting reading.
DOES ANYONE HAVE SPECS FOR THE FISHER-PRICE FP-000968-9013 ???
Unread 18-01-2012, 13:42
Motor calculator has been updated to MCALC32t and includes:
The calculator now gives the user the option to select which specs to use for am-0914, since there are 3 different sets of specs (explained in the am-0914 options menu).
Unread 19-01-2012, 11:13
MCALC32w fixes a problem with the spec options menu for the am-0914.
Unread 19-01-2012, 17:56
MCALC32aa adds a UserDefined motor to the motor selection menu.
EDIT: MCALC32ab adds exception handling to user-defined motor input
Unread 27-01-2012, 15:18
bmlarson12 bmlarson12 is offline
FRC #1977 (LHR)
Team Role: Electrical
bmlarson12 is an unknown quantity at this point
WOW!!! How did you do this? I have been looking for a graph of the information so I could get the general values, but this is far better!
