Go to Post You're on a team, weren't you taught Gracious Professionalism? It doesn't only apply to competitions, it applies to the real world. - Zac Schofield [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 13-01-2011, 22:02
TPNigl TPNigl is offline
FRC #0069 (Team HYPER)
TPNigl is an unknown quantity at this point
CAN in Java?
Hello there! So I've been poking around Chief Delphi and haven't found a simple answer to this question (although I could be partially blind and just have skipped over it). How do you program a CAM system in Java?
Our team is seeing if we want to try the CAN system this year and they want to make sure the code will work for it completely if we do switch.
Also, aside from the code itself, is there anything that I should watch for that is different from PWM's?
Thanks everybody!
2011 Pit Crew:
2011 CT Xerox Creativity Award
HYPER Alumni
Unread 13-01-2011, 22:26
Kevin Wang's Avatar
Kevin Wang Kevin Wang is offline
Software Engineer, Webmaster
FRC #0694 (StuyPulse)
Kevin Wang is an unknown quantity at this point
Re: CAN in Java?
Use the CANJaguar class.
Unread 13-01-2011, 23:12
Re: CAN in Java?
Wow, that's pretty obvious xD Thanks, hahaha
2011 Pit Crew:
HYPER Alumni
Unread 16-01-2011, 12:35
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: CAN in Java?
Please note that the CANJaguar appears to be currently broken at least as far as the serial to can goes. Please see the thread titled Updated Jaguar Can Issues
