Go to Post On the one hand, I wouldn’t want to discourage innovation. But on the other, I would want to encourage simplicity. - Jack Jones [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 11-01-2011, 01:03
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Winpdb Remote Debugger ported to RobotPy
Hey, I've been playing with RobotPy quite a bit lately, and one thing you'll probably note is that debugging scripts is a bit annoying. Ok, more than just a bit annoying... haha. Anyways, here's a great solution to solve that problem! Winpdb is a GPL remote debugger that works pretty well from what I can see so far, and gives you full source debugging over the network. I've modified it a bit so that it works on RobotPy. Check it out:
http://www.virtualroadside.com/blog/...py-on-vxworks/
Note: Contrary to its name, Winpdb is cross platform, it just requires wxPython to run.
Unread 12-01-2011, 02:04
Slix Slix is offline
AKA: Peter Kowalczyk
FRC #2115 (NightMares)
Slix is an unknown quantity at this point
Re: Winpdb Remote Debugger ported to RobotPy
Sounds like this will really help! Unfortunately, I can't try it out on our robot until Monday. D:
Unread 13-01-2011, 21:11
blakeelias's Avatar
blakeelias blakeelias is offline
2011 CT chairman's award
FRC #0694 (Stuypulse)
blakeelias is an unknown quantity at this point
Speaking of debugging, have you found a way to compile and check your scripts *before* running on the robot?
In Java NetBeans would compile our code locally and show where we had syntax errors or improper API calls, but with Python we don't find this out until runtime. This makes it hard to work on code when there is no robot access, since someone's usually working on it mechanically.
So far I can check syntax with:
python3.1 -c "import py_compile; py_compile.compile('robot.py')"
However that does not seem to catch many of the problems we'll run into, like misspelling function names and other common errors.
Any ideas?
Unread 13-01-2011, 23:52
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Any ideas?
Indeed that's the downside of using a dynamic language.. static analysis is pretty much impossible (look up the halting problem). The long term solution will be a robot simulator (written in Python?) that provides an emulated Python wpilib so you can test your code offline. I've started looking at this but it's a pretty large project (the simulator is hard enough but there's also a LOT of wpilib classes to write emulated versions of).
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 14-01-2011, 23:38
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
i have a virtual robot thing half put together
#This file should emulate enough of wpilib to make it usable for testing
#DONE: use pygame to get joystick inputs from actual joysticks
print("="*40)
print("TESTING.PY LOADED, IF THIS IS ON THE ROBOT CALL SAM *NOW*")
print("NNN NNN NNNN")
print("="*40)
try:
    import pygame
    import pygame.joystick
    pygame.init()
    print(str(pygame.joystick.get_count()) + " Joysticks attatched")
    new = True
except:
    new = False
    print ("NO PYGAME FOUND")
def limit(n):
    if n > 1.0:
        return 1.0
    elif n < -1.0:
        return -1.0
    else:
        return n
class Victor:
    def __init__(self, port):
        self.port = port
        print("Virtual Victor set up on port " + str(port))
        self.speed = float()
    def Set(self, speed):
        """***FOR TESTING PURPOSES ONLY***
       This "sets" the virtual Victor to any arbitrary speed"""
        speed = limit(speed)
        print("on port " + str(self.port) + " the speed is now " + str(speed))
        self.speed = speed
    def Get(self):
       This emulates the wpilib.Victor.Get function"""
        return self.speed
class Joystick_old:
        self.port = port
        print("New FAKE joystick set up at port "+str(port))
    def GetRawAxis(self, n):
        return float()
    def GetRawButton(self, n):
        return False
class Joystick_pygame:
        self.port = port -1
        self.joy = pygame.joystick.Joystick(port-1)
        self.joy.init()
        print("made new pygame joystick on port " + str(port))
        print(self.joy.get_name())
        pygame.event.pump()
        return self.joy.get_axis(n-1)
        pygame.event.pump()
        r = self.joy.get_button(n-1)
        if r == 1:
            return True
        else:
            return False
def Joystick(port):
    if new:
        print("trying to use awesomesauce new features")
        try:
            print ("can use awesome features")
            return Joystick_pygame(port)
        except:
            print ("cannot use awesome new features")
            return Joystick_old(port)
    else:
def speedReport(list_obj):
    """Use this for the driver object"""
    for n in list_obj:
        n.Get()
def IsDisabled():
    return False
def IsAutonomous():
    return False
def IsOperatorControl():
    return True
def IsEnabled():
    return True
class dummyDog:
    def SetEnabled(self, var):
        pass
    def SetExpiration(self, var):
        pass
    def Feed(self):
        pass
    def Kill(self):
        pass
def GetWatchdog():
    return dummyDog()
def Wait(n):
    pass
class Solenoid:
    def __init__(self, slot, port):
        self.slot = slot
        self.port = port
        print("Solenoid set up on slot " + str(slot) + " port " + str(port))
    def Get(self):
        return self.state
    def Set(self, state):
        self.state = state
        if state:
            print("port " + str(self.port) + " active")
        else:
            print("port " + str(self.port) + " inactive")
class Relay:
        self.port = port
        print("Relay set up on port " + str(port))
        self.kForward = 1
        self.kOff     = 2
        self.kReverse = 3
    def Get(self):
        pass
    def Set(self, value):
        if value == self.kForward:
            print("relay forward")
        elif value == self.kOff:
            print ("relay off")
        elif value == self.kReverse:
            print ("relay backwards")
class Compressor:
    def __init__(self, port1, port2):
        pass
    def Start(self):
        print ("compressor on")
    def Stop(self):
        print ("compressor off")
class SimpleRobot():
    def StartCompetition():
        run_old()
edit:
Wow, i was high when i wrote this, pasted wrong file
