Re: Power Converter 360 CPR
Thanks for all the info guys! I passed it all on to our electrical girls.
Ours only puts out 4.1 volts, not enough for the radio.
They do not supply them from the US only China. Price is reasonable. I have a question in to FIRST about what we can substitute. Current-Logic's P/N is TBJ12DK025Z. Charlie Affel, 1712 |
You must use the same model of the power convertor that came in the kit, I believe if I remember the rules correctly.
Yes that's the rule R38.
Everyone needs to power their radio and our converter is broken. Some remedy is required. |
The current supply from the 5V output on the PD board is rated for 3A, which is plenty enough to run the Dlink. The 5V output is not a boost supply, so low battery voltage, or huge current spikes can cut power to the Dlink. I don't see any issue in doing this. Maybe some other mentors can post and tell me their thoughts. I know this isn't a FRC legal idea, but to get the team up and running, it seems like a good temporary idea. |
Can someone post a question to the Q&A? That way we can get an official 'fix'.
#7
Our 360CPR is not working also. We asked Q&A the first part of February what the alternative can be and they have not responded yet.
#8
FIRST has a lot going on and simply wants to eliminate debugging radios resetting from low power from all the other stuff that breaks at the most inopportune moments for the field crew The boost supply on the 12V rail helps with that, but it was previously designed for the Linksys bridge, so we need the new converter to bridge the gap between the reliable supply, and the lower voltage radio.Matt |
#9
Just heard that our power converter is toast. Going there in about an hour to see if I can get things working. Put together a 12V to 5V linear for a temporary patch, hope I don't need it. Probably hook it up to the camera supply until we get a replacement.
Took a look at the D-Link user manual, it uses 3.3V internally with a maximum current of 1.435A. (Never saw a spec of current consumption out to 3 places.) So apparently, there it has an internal dc/dc to drop the 5 down to 3.3V. I would be suprpised if it was less than 85% efficient, so (3.3*1.435/0.85) is 5.6W, which suggests it really needs about 1.11 amps at 5V input. |
#10
Here's the link to order a new one: http://www.current-logic.com/dc_dc_c...RC_360_CPR.php
The parts table at competition may have a few of these in stock for teams to borrow if you cannot get one shipped before competition. |
#11
All,
Thanks to a heads up by Joe Ross on this availability issue. I just put a request in to this company to purchase 100 of these converters. If we can get some soon (within 2 weeks?), then we will purchase at least 100 and then offer them for sale through the AndyMark site. I really don't know how big of an issue this is going to be, so if anyone wishes to send me a PM or email, letting me know that your team may want one, that will help me figure out how many to buy. Andy B. |
#12
The power converter used in the DSC and the first public revision of the analog breakout module meets the requirements for this task. An ugly but effective hack would be to power one of these with the dedicated (boosted) 12V supply from the PD, and use that to power the radio.
However, there are some drawbacks:
#13
Update from AndyMark:
Our purchase of 100 units has been shipped from China, and we are receiving these this week. A new part on our website has been created (am-0899), and this part will hopefully be available by March 3rd (or a bit later, if the shipment is delayed). Sincerely, Andy Baker |
#14
