Go to Post theres nothing more macho than something made entirely out of diamond plate. - Dan9874123 [more]
Unread 14-01-2011, 00:21
Aren_Hill's Avatar
Build Nifty Things
Re: JVN Build Tip: Prototyping
Originally Posted by iCurtis View Post
John,
From the pictures you post, it seems like 148 moves directly from cardboard and Vex into sheet metal and the production robot. Is this the case? For the robots I've worked on, we typically went from cardboard to plywood to plywood & shafts powered by drills to rough cut aluminum then to the final robot part. It seems like you skip by that rough aluminum step. I know you use a lot more CAD than we did, but do you just trust that your Vex and cardboard dimensions are "good enough"? Or do you end up rebuilding some manipulators if you find that your dimensions don't work as well as you anticipated?
I know they plan in adjustable features by adding extra sets of holes and such, we may have copied this attribute when we stole their entire 2007 arm effectively....
A guy who likes robots.
Unread 14-01-2011, 01:02
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Good point. Having flexibility with mounting points on a final piece can help out later down the road if something changes. Plus extra holes = less weight
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
