Go to Post Organization is the one skill that can help make *any* workshop work. - tjf [more]
Unread 14-01-2011, 09:23
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: IF NEEDING HELP POST HERE!
Originally Posted by J-Mech View Post
Yes we have the IP set up for the cRIO and it is connected to the developer computer with the Ethernet cable. I connected the system to the classmate and it was a communications error(Fast Blink). I have verified that all of the IP addresses are set to what the manual gave for configuring the cRIO.
If I understand what you're doing correctly, that won't work. The cRIO port 1 is the only port that can be used for communication, port 2 is for sensors/other devices. So from what I understand you have setup, you have the development computer connected to the cRIO port 1 (using an ethernet cable, which is wrong, should be a crossover). You also have the classmate connected wirelessly to the Bridge, and the Bridge ethernet cable is connected somewhere it shouldn't be.
The first configuration I would try is connect your development computer with a crossover cable to the cRIO port 1, and using the IP settings I gave earlier. If you can ping it, that means that the cRIO is imaged, I believe. I would stick with the LabView image if you follow my troubleshooting advice, since I don't have working knowledge of WindRiver. Then you should connect to the cRIO using LabView with a default project and build/run as startup to get working code on the cRIO.
After all these steps are completed successfully, I would start with checking out the wireless configuration/communication with the Classmate.
If you are unsure of anything I've said here, refer to these documents:
http://www.usfirst.org/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2011_Assets/Kit_of_Parts/How_to_Build_and_Load_Programming_in_LabVIEW,_C,_a nd_Java.pdf
http://www.usfirst.org/uploadedFiles...cRIO_Rev_A.pdf
I really wish they would have made the control system instructions in one document this year, so teams knew how to progress through the documents instead of a collection of separate documents. If they would have been consolidated (like last year) I believe that your team would probably not be having this problem.
